How can I allow user to turn on/off autoanswer for the line?
hxmengmetro
We have a request to turn on/off autoanswer for the agent lines. The setting is in callmanager line level. I logged in personal phone page and didn't see any option user can change autoanswer feature. Is there any customized way like a service to turn on and off that feature? Thanks!
Lou
Jaime Valencia
No, this requires CCMAdmin access natively, you would need to write down your own AXL script to do this via your own webpage.
java
if this helps, please rate
Jaime Valencia
java
Thanks Jaime. So can I write own AXL script to edit individual line when they login with credentials?
Lou
I don't work with AXL, not sure if there's a way to use authentication like a UCMuser page to get only your line, you might want to continue this discussion on a developer forum
java
Thanks Jaime
