How can I edit/add/remove speed dial assignements thru CLI
victor.oshiro
I was wondering if you could give me some help on how to remove/edit the speed dials assgigned to a specific extension.
On my phone display is showing  other person name ( as this person was set up as speed dial #1)
also want to remove the labels on speed dials.
thanks
v
    Here is the information on speeddial,
     http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmespeed.html
Please use the "no" form of the command to remove the speeddial or label. just use the command 'restart' in the ephone to apply the change on the actual phone.
For example,
ephone 1
mac-address 1234.5678.ABCD
button 1:24 2:25
speed-dial 1 +5002 label Receptionist
speed-dial 2 +5001 label Security
use no form, to remove it,
ephone 1
button 1:24 2:25
no speed-dial 1 +5002 label Receptionist
Please rate if this helps, by clicking the stars below.
11 Replies 11
paolo bevilacqua
Start mentioning system type and version you're using.
THe Cisco IP phones are 7941,7942,7962
the phone system is 2911 router, if you could let me know how can i cehck the version i can try.
thanks
You can edit these with CLI under ephone, or from the phone GUI.
Restart phone after done editing.
yes, that's why I post this question asking for the syntax of the command to edit/delete the speed dials and labels.
could you help with it?
The CME configu guide is what you're looking for
Cisco Unified Communications Manager Express System Administrator Guide
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Jaime,
I was unable to open that link , seems some restrictions, could you give me another link for that or paste differently?
Just remove partner/ from the link after you copy it
java
java
It will work if you copy the whole link... You're missing .html...
your question on how to configure the directory is also addressed in there
You should review the whole guide as it contains all the CME config.
java
For example,
ephone 1
button 1:24 2:25
ephone 1
button 1:24 2:25
Thanks to all of you for your posts . It solved my issue.
