06-08-2022 09:54 AM
06-08-2022 11:45 AM
AFAIK there is no way to busy out a directory number in CM.
06-10-2022 05:17 AM
Are there any alternative ways to accomplish the same thing?
06-23-2022 02:00 AM
perhaps put those extns in an isolated partition (which is not added in any CSS).!!!?
06-28-2022 03:15 PM
If the DN is on a phone, put the phone in Do Not Disturb (soft key or check box on phone config), with DND Option set to "Call Reject"
On the DN, make sure all forwarding is disabled/unconfigured. If you do all these, inbound calls will return an actual busy signal.
