03-14-2016 02:13 AM - edited 03-17-2019 06:13 AM
Hi everyone,
I can't find where to enable this option, and I've used wireshark to ensure that it isn't enabled by default.
Any ideas?
03-14-2016 02:31 AM
I suppose u are referring to firmware download/sw upgrade through http in which port 6970 is used.
It is enabled by default and there is not setting for configuring. You can do packet capture from phone by enabling span to pc port and check for port 6970.
regds,
aman
03-14-2016 02:57 AM
Hi Aman,
I'm referring to the new feature in CUCM 11.x which allows downloading via HTTPs rather than HTTP.
We're using Mixed Mode with LSCs.
Performing a wireshark capture shows that HTTP is used and not HTTPs, so it may be something that needs to be configured.
03-14-2016 03:16 AM
Not aware if any such setting is there for HTTPs.
regds,
aman
03-14-2016 08:01 AM
The feature appears in the security guide and the release notes, but it's not clear how to enable it. I've tried regenerating callmanager and CAPF, then restarting their services. This is after migrating to 11.x. Nothing changed.
03-14-2016 04:59 AM
Note: This is after migrating from 8.6.2 to 11 so that the LSCs and CAPF are migrated from 8.6. Could this have an impact?
