How do I install Cisco TSP Client
jglass
Hello
I am trying to integrate a new clients Cisco IP PBX with a commercial real estate management software using the Windows phone dialer. I have done some research and I think I just need to install the Cisco TSP Client, which includes the Cisco TAPI Wave and media drivers.
does any one know how I can find the TSP Client or where I can download it. Client is currently using Cisco Call Manager Express, but he doesn't know where the install CD is.
Thanks in advance for the help.
Best regards,
Joshua
5 Replies 5
Hi Joshua,
Generally you can download the TSP frpm CME from the following link:
http://www.cisco.com/cisco/software/type.html?mdfid=277641082&catid=null
HTH,
Christos
Thanks for the link, is client required to have CME installed to use the Cisco TAPI funtions?
Josh
TSP is normally used to control a phone that is registered to CME via an application that is installed in a PC.
So yes you need to have CME and phones registered to it to be able to use TSP / TAPI
HTH,
Christos
Thanks fo rthat info, I have just 2 other questions.
1. If client has lost the CD and doesn't have a Cisco ID or Support Contract can a new CD be ordered?
2. How do I setup user names and passwords for CME?
I have had some training on UC and CME but have never actually deployed it before. The client has CME setup for front desk, but I need to install and configure CME and TAPI for the VP and his associate and integrate their commercial real estate management software  with Cisco IP phones using TAPI / TSP client.
Thanks again for all of your help.
Best Regards,
Josh
It should be under the ephone configuration.
Here is a sample config I found in one guide
ephone 1
username "User 1" password user1
mac-address 0009.B7F7.5793
speed-dial 4 3100 label "AA"
button 1:1
Regarding the ordering of a CD I would say no but then again it is better to call customer service to be sure. Here is the relvant link
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_qanda_item09186a00802262ed.shtml
Christos
