06-11-2015 01:59 AM - edited 03-17-2019 03:18 AM
There is a way to have my company name instead of the original number displayed on my outgoing calls outside my company?
I know I can mask the internal 4 digits extension, but I have a requirement to show company name instead.
I am using CUCM v 10.5.1.10000-7
Many Thanks
06-11-2015 02:29 AM
This feature can be enabled if your Telco allows it, please check the following post for a detailed explanation
https://supportforums.cisco.com/discussion/11302061/set-outbound-caller-id-name
Manish
06-11-2015 07:02 AM
Or you can set the ASCII display name to your company for all DNs, or configure a TCL script to do this change.
