01-18-2017 07:26 AM - edited 03-17-2019 09:13 AM
I am trying to find out what is the maximum in/out calls that can be made
Ran a command on voice-gateway "voice
#show voice
DSP groups on slot 0:
dsp 1:
State: UP, firmware: 4.4.801
Max signal/voice channel: 16/16
Max credits: 240
Group: FLEX_GROUP_VOICE, complexity: FLEX
Shared credits: 165, reserved credits: 0
Signaling channels allocated: 16
Voice channels allocated: 5
Credits used: 75
Voice channels:
Ch01: voice port: 0/0/0:23.23, codec: g711ulaw, credits allocated: 15
Ch02: voice port: 0/0/0:23.1, codec: g711ulaw, credits allocated: 15
Ch03: voice port: 0/0/0:23.2, codec: g711ulaw, credits allocated: 15
Ch04: voice port: 0/0/0:23.21, codec: g711ulaw, credits allocated: 15
Ch06: voice port: , codec: None, credits allocated: 15
dsp 5:
Max credits: 240
Shared credits: 240, reserved credits: 0
Signaling channels allocated: 7
Voice channels allocated: 0
Credits used: 0
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
Solved! Go to Solution.
01-18-2017 07:42 AM
Yes, 16 voice channels or simultaneous calls. I'm assuming this is a PVDM2-16? Take a look at the following document for further explanation regarding the output.
https://supportforums.cisco.com/document/123061/understanding-output-show-voice-dsp-group-all
Brandon
01-18-2017 09:26 AM
You only have a PRI, so that's 23 channels, 23 calls.
controller T1 0/0/0
framing esf
linecode b8zs
cablelength short 133
pri-group timeslots 1-24
description PRI
01-18-2017 07:42 AM
Brandon
01-18-2017 07:47 AM
01-18-2017 07:56 AM
Assuming PRI? PRI is 23 voice channels and 1 signalling channel. Between the 2 DSPs you should have enough resources.
The DSP calculator is a helpful tool for determining the necessary resources based on router, IOS, number of channels needed, etc.
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Brandon
01-18-2017 08:00 AM
Looks like my model is not
vgw5#show ver
Cisco IOS Software, 2800 Software (C2800NM-IPVOICE-M), Version 12.4(1a), RELEASE SOFTWARE (fc2)
01-18-2017 08:13 AM
I wonder what are those voice channel allocations mean.. because dsp1 has 6 voice channels allocated and dsp5 - only 2.
01-18-2017 08:31 AM
From your post above I see 5 voice channels allocated for dsp1 and none for dsp2. Looks like you have channels configured for port 0/0/0. Partial PRI?
01-18-2017 08:35 AM
ok, I've just figured that these numbers seem to change every in a while by running 'show voice
01-18-2017 08:44 AM
It would be easier if you just post your sh run
01-18-2017 09:13 AM
here it is:
vgw5#show run
Building configuration...
Current
version 12.4
service timestamps debug
service timestamps log
service password-encryption
hostname vgw5
boot-start-marker
boot system flash c2800nm-ipvoice-mz.124-1a.bin
boot-end-marker
logging buffered 128000 debugging
enable secret 5
enable password 7
aaa new-model
aaa group server radius RADIUS-NPS
server-private 10.1.4.241 auth-port 1812 acct-port 1813 key 7
server-private xxx auth-port 1812 acct-port 1813 key 7
aaa authentication login default local group RADIUS-NPS
aaa authorization exec default local group RADIUS-NPS
aaa session-id common
resource policy
clock timezone EDT -4
network-clock-participate
network-clock-select 1 T1 0/0/0
no
voice-card 0
no
voice service
h323
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice statistics type csr
voice statistics time-range since-reset
username manager password 7 xxxxx
controller T1 0/0/0
framing esf
linecode b8zs
description PRI
translation-rule 1
Rule 1 ^1.% 91
Rule 2 ^2.% 92
Rule 3 ^358.% 9011358
Rule 4 ^3.% 93
Rule 5 ^44.% 901144
Rule 6 ^4.% 94
Rule 7 ^5.% 95
Rule 8 ^6.% 96
Rule 9 ^7.% 97
Rule 10 ^8.% 98
gw-accounting syslog
interface FastEthernet0/0
ip address xxxx
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
isdn switch-type primary-ni
isdn incoming-voice voice
isdn map address .* plan unknown type unknown
isdn T310 60000
no cdp enable
interface Service-Engine1/0
ip unnumbered FastEthernet0/0
shutdown
service-module ip address xxxxx
service-module ip default-gateway xxx
no ip http server
logging xxx
access-list 57 permit xxx
snmp-server community xxx RO
snmp-server location xxxx
control-plane
call filter match-list 1 voice
voice-port 0/0/0:23
dial-peer voice 1 pots
destination-pattern 9T
progress_ind alert enable 8
progress_ind progress enable 8
incoming called-number 2...
direct-inward-dial
port 0/0/0:23
dial-peer voice 911 pots
destination-pattern 9911
direct-inward-dial
port 0/0/0:23
prefix 911
dial-peer voice 11 voip
destination-pattern 2...
progress_ind setup enable 3
translate-outgoing calling 1
voice-class codec 1
session target ipv4:xxxxx
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 2 pots
incoming called-number 4...
direct-inward-dial
port 0/0/0:23
dial-peer voice 12 voip
destination-pattern 4...
voice-class codec 1
no vad
dial-peer voice 3 pots
incoming called-number 5...
direct-inward-dial
port 0/0/0:23
dial-peer voice 13 voip
destination-pattern 5...
voice-class codec 1
no vad
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
timeouts interdigit 5
ip source-address 10.6.1.251 port 2000
max-ephones 42
max-dn 60
voicemail 2390
moh music-on-hold.au
time-format 24
date-format dd-mm-yy
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output all
line vty 0 4
exec-timeout 30 0
password xxxxxx
scheduler allocate 20000 1000
ntp master
end
01-18-2017 09:26 AM
controller T1 0/0/0
framing esf
linecode b8zs
description PRI
01-18-2017 08:44 AM
but you are right it is on 0/0/0 and PRI.. :
vgw5#show controller T1 0/0/0
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is short 133
Description: PRI
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20041023, FPGA: 16, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from
