How many calls handle by CUBE gateway
Sanjay Bishnoi
I have one Cube gateway with 25 license but here is the question...how many calls will be delivered or connected in this scenario.
17 Replies 17
Hi Sanjay,
CUBE is a paper-based honor license (no file to install) that allows you to run the CUBE RTU (Right-to-Use) feature set after you have the UCK9 license installed.
So ideally if you are continually exceeding 25 then you should buy more licences, but the exact capability again falls to hardware capability as of now.
Does that make sense?
JB
Hi  Jitender,
We have 3 PVDM with 256. so how many calls can be handled by the Cisco 3945 and 2921 gateway.
Is it the same 950 calls or more?
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE250/K9 with 1782784K/314368K bytes of memory.
8 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
256K bytes of non-volatile configuration memory.
2005920K bytes of ATA System CompactFlash 0 (Read/Write)
NAME: "Cisco Services Performance Engine 250 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 250 for Cisco 3900 ISR"
PID: C3900-SPE250/K9 , VID: V05 , SN:
NAME: "4 Port GE Non-POE EHWIC Switch on Slot 0 SubSlot 0", DESCR: "4 Port GE Non-POE EHWIC Switch"
PID: EHWIC-4ESG , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 256 Channels on Slot 0 SubSlot 3", DESCR: "PVDM3 DSP DIMM with 256 Channels"
PID: PVDM3-256 , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 256 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 256 Channels"
NAME: "PVDM3 DSP DIMM with 256 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 256 Channels"
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC , VID: V04 , SN:
NAME: "C3900 AC Power Supply 2", DESCR: "C3900 AC Power Supply 2"
1627684864 bytes available (426049536 bytes used).
3 PVDM with 256
