02-27-2016 05:47 PM - edited 03-17-2019 06:03 AM
Hi It looks like only one softphone can be installed on one PC. I tried to install two, but failed. How do you think about it?
Solved! Go to Solution.
02-27-2016 08:00 PM
Only one. Try IP blue that allows to run multiple instances at a given point of time but I think in trial version, you can only use them for 20 minutes and launch again.
https://www.ipblue.com/products_vtgo_multilab.asp
Deepak
02-27-2016 08:00 PM
Deepak
02-27-2016 08:41 PM
Thank you!
