How to access web interface 8841
Hi! What is the exact url to access the web interface of a CISCO 8841?
Firmware version: sip88xx.12-1-1SR1-4
I have already modified the XMLDefault file, adding:
<enterpriseConfig>
<webAccess>0</webAccess>
<eapAuthentication>2</eapAuthentication>
<webProtocol>0</webProtocol>
</enterpriseConfig>
Thank you,
Luigi
6 Replies 6
George Sotiropoulos
Is this registered on a CUCM? If yes, then you need to enable the web access setting (bottom on specific phone configuration).
G
please rate, if useful
Hope the above helps,
gsotirop
No. I used a tftp server to update firmware.
But now i would like to configure the sip proxy, in order to use the phone with a custom call manager.
And i can't find a "proxy option" to do that. So i thought i had to access the web interface to have some more options to configure.
I would suggest to manually configure these settings on the phone (if this is next to you).
You can try to assing the IP address of your PBX on the TFTP server setting of the 8841 and see if this works for you.
G
gsotirop
If you're running enterprise FW there is no configuration GUI, there's only a view only GUI where you see the configuration the phone gets from CUCM.
java
if this helps, please rate
Jaime once more is totally right
gsotirop
Leo Laohoo
What are you trying to do?
Web access only gives the operator a "show" command. There is no way to make any configuration or behavioral changes via web access.
