how to add FL-SRST-35 license on 2811?
ashah5053
I presently have 2811 with 'c2800nm-advipservicesk9-mz.124-15.T10.bin' ios.Now i want add FL-SRST-35 license for which i have to upgrade ios to 15.1 and upgrade DRAM and flash as required.But i am stuck in ios upgradation from 12.4 to 15.1 wether it would a upgrade license or i can download it or how does it go.Please help
5 Replies 5
ashah5053
Forgot to mention SRST version 8.6
FL-SRST-35 are paper licenses and are not to be uploaded in router.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Also make sure you are downloading only advipservicesk image in 15.1 and not any other.
Ronak Patel
ok...thanks a lot
HI
If it helped , you can rate the post.
Ronak Patel
