03-06-2013 03:24 AM - edited 03-16-2019 04:05 PM
What could be the reason why the following is happening:
- we have a route pattern to the pstn pointing to a RG that has a H323 gateway
- there is another SIP trunk to the same gateway but this trunk is not attached to any route pattern
- there is a VoIP dial peer using SIP toward the CUCM and a non-SIP dialpeer towards the CUCM
now when we make in an inbound call, incoming dial peer pots, outgoing the non-SIP towards CUCM
outgoing calls, the inbound is the SIP dialpeer on the voice gateway, not the non-SIP as I would have expected
any tips, thanks
03-06-2013 03:33 AM
You will need to examine your dial-peer configuration to see why the sip dial-peer is matched..
You can use debug voip dialpeer to see this..
you can also send your config here and we can help..please include calling and called number
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
03-06-2013 03:36 AM
dial-peer voice 2901 voip
description SIP_TRUNK_CUCM
destination-pattern .T
session protocol sipv2
session target ipv4:10.1.7.7
session transport tcp
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
no vad
dial-peer voice 10000 voip
description H323
destination-pattern 92481...
codec g711ulaw
dtmf-relay h245-alphanumeric
progress_ind setup enable 3
progress_ind progress enable 8
voice-class h323 1
no vad
03-06-2013 03:38 AM
What is the called number? and if you can debug voip dialpeer, that will be good
03-06-2013 03:42 AM
incoming it uses the 10000 as expected towards the cucm
but it uses the 2901 when making a call towards the PSTN, there are not route pattern using the SIP trunk so why is it using that dialpeer instead of the other one
if I remove 2901 then incoming calls don't work either
----- ccCallInfo IE subfields -----
cisco-ani=092481200
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=037776616
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Mar 6 10:51:38.856: //-1/005394D0142E/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2B2FD9A8, Call Info(
Calling Number=092481200,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=037776616(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=2901, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=3910
03-06-2013 04:17 AM
This is because your called number is 037776616.
It only matches on the 2901 dial-peer..
The 10000 dial-peer only matches any number beginning with 9
description H323
03-06-2013 04:24 AM
changed it so 10000 was exact copy of 2901 (but no SIP) but same behaviour
03-06-2013 05:16 AM
If you have both dial-peers pointin to same destnation--and you want to use 1000, then you need to configure lower preference on the 2901
preference 1
03-06-2013 05:27 AM
the thing is... why is it using that 2901 dialpeer with SIP and not the one without SIP, we did some further testing with even longer matches but the gateway refuses to use those (destination pattern complete number)
removing the that one even breaks incoming calls... the only way to have incoming working, is using the above dialpeers
03-06-2013 05:37 AM
I have answered your question..thje sip dial-peer has a better match (.T) The 1000 dial-peer has match with 9T
When you changed your config and make 1000 with destination-pattern .T
you then have two dial-peers
description H323
So when a call comes in you match both dial-peer, and then your dial-peer hunting algorithm comes into place
The default is 2
2—Explicit preference, longest match in phone number, random selection
So the dial-peer will be selected randomly..
03-06-2013 05:42 AM
longest match.... why does it use the 2901 when 10000 has the complete number as destination pattern
03-06-2013 05:45 AM
Your destination-pattern on 10000 is destination-pattern 92481.....
How is that the longest match?
03-06-2013 05:48 AM
As stated before those are the dialpeers to get incoming calls working
I said that we changed our destination patterns in the course of the day but results always showed dialpeer 2901 used no matter what we did with 10000 (see post 6:27am well that is what I see here)
removing dialpeer 2901 then no incoming calls work at all
03-06-2013 05:57 AM
ok,
Please send me the correct information..
The current dial-peer config..
the calling and called number
if you can..debug voip dialpeer
