How to adjust LMR VOX threshold
Hans Johnson
I have a mostly functioan LMR setup going, using a VIC2-2E/M in a 3825.  I am hoping to use this to allow phone users to link to our radio network.  Unfortunately, the VOX as generated by the cisco router is at too low of a threshold, so the router keys the radio based even on minor noises.  I have the system setup as a simple dial-peer and voice port, and am trying ot use the "lmr ip-vad" function.  Is there a way I can set the threshold for ip-vad so that it will not key up the radio on background noise?
Here is my configuration:
voice-port 0/0/0
auto-cut-through
operation 4-wire
type 2
signal lmr
lmr e-lead voice
lmr duplex half
lmr ip-vad
lmr led-on
input gain 5
output attenuation -16
no echo-cancel enable
no comfort-noise
timeouts call-disconnect 3
timeouts ptt rcv 3
timing hangover 300
music-threshold -10
threshold noise -60
dial-peer voice 16 pots
destination-pattern 2505
port 0/0/0
What happens is that when you dial 2505, it connects and will key up the radio when you talk, but it will aso just randomly key up the radio causing all sorts of havoc.  What I am looking for is a way to modify the threshold so it takes more voice energy to key up the radio.
Hans
Have a look at the following document from page 8 onwards:
http://www.cisco.com/en/US/docs/interoperability_systems/c_ipics/211/design/guide/sr211lmr.pdf
llowing shows a sample configuration for an LMR voice port that is configured for VAD operated
signaling.
In this example, type { 2 | 3 | 5 } typically is type 3, but refer to
Figure 3-3 on page 3-5
Figure 3-4 on
page 3-6
, and
Figure 3-5 on page 3-7
to select the type that best matches your radio requirements. Input
gain { -27 - 16 } typically is 10, but adjust this value as needed to best receive audio on Cisco IPICS
endpoints. Output attenuation { -16 - 27 } typically is 10, but adjust this value as needed to best receive
audio on radios. When connecting a radio to a voice port in an LMR gateway, you may need to make
adjustments to properly balance the audio levels. A
radio typically provides gain adjustments, and the
level of the signal from the radio to the voice port and the level of the signal from the voice port to the
radio may require some adjustments on the radio and
the voice port. When using a tone controlled radio,
it is important to note that the tones that are sent fr
om the LMR gateway to the radio also are affected by
the voice ports output attenuation settings. When opti
mizing these settings to achieve the desired audio
levels, take care to ensure that th
e voice port adjustments do not have
an adverse effect on the level and
quality of the tone signals.
voice class permanent 1
signal timing oos timeout disabled
signal keepalive disabled
signal sequence oos no-action
voice-port 0/2/1
voice-class permanent 1
auto-cut-through
operation 4-wire
type { 2 | 3 | 5 }
signal lmr
lmr e-lead voice
lmr duplex half
lmr led-on
input gain { -27 - 16 }
output attenuation { -16 - 27 }
no comfort-noise
timeouts wait-release 3
timing hookflash-in 10
timing hangover 40
connection trunk 102
description VAD Operated Voice Port
threshold noise -40
dial-peer voice 102 voip
destination-pattern 102
session protocol multicast
session target ipv4:239.193.1.2:21000
codec g711ulaw
vad aggressive
Best Regards
Hi Hermanus,
I've read through the documentation that you cited prior to posting the question, but I'm not sure how it helps (perhaps it does, and I'm just missing it).  In the above config snippet you posted, lmr e-lead voice means that it will seize the e-lead when it receives voice packets from the network, relying on the far-end VAD to do the voice gating/VOX stuff.  This is problematic since I'd lke to be able to, say, conference the radios with a remote caller as well as someone local.
The configuration directive of "lmr ip-vad" is supposed to set it up so that the DSP watches the inbound voice packets from the network, and only cause the port to seize when there is actually voice energy in those packets.  The problem is that it's too sensitive.  I was/am hoping there is a way to adjust these thresholds.
Thanks for your time.
