09-16-2010 04:07 AM - edited 03-16-2019 12:49 AM
I have a requirement to allow an Analogue Phone, (plugged into an ATA) to transfer calls to another IP Phone. Do you have any idea how to do this? The Analogue phone is a Cordless (Wireless Analogue Phone)
I have seen on CCM ver 6.1.4 that in Enterprise Parameters there is an option for Enterprise Feature Access Code for Transfer but that is in reference to Mobility!
I have tried configuriung a Translation pattern with ***XXXX so from the analogue phone you can dial ***XXXX the 4 digit extension but this doesnt work. I think you have to do something with Hook Flash so that the Analogue phone gets a 2nd Line but do not know how to do this.
I have since Found the guide below:
Step 1 While engaged in a call, perform a hookflash, then press 2 on your telephone keypad.
Step 2 After the dial tone sounds, enter the telephone number.
Step 3 When the other party answers or the remote telephone rings, hang up to transfer the call. You can perform a hookflash at any time to halt the operation and resume the original call.
However, how do you do a Hook flash on a Cordeless Analogue phone?
Ash
09-16-2010 05:41 AM
Hi Ash,
Most Cordless phones have a button on them that simulates a Hookflash
this is usually labelled Flash, Link or re-call. Can you let us know what make/model
of cordless phone you are using and we'll do some research
Cheers!
Rob
09-16-2010 09:09 AM
Thanks Rob
I have tried the 'Recall' button and it all works great! In the meantim i als started looking at the STIG timers on the ATA under its development pasges for max Hook flash timer settings, but now it works with the R button its all fine!
Ash
