How to calculate Max Outbound calls per second on Cube?
johngalek
I have a few cisco cubes with different providers! Is there an easy way to calculate max outbound calls per second, per cube? I am struggling- CUIC/RTMT/CUCM/CLI?  Any help or direction would be appreciated.  Would like to do last 30 days or all history?
2 Accepted Solutions
Hello John, the most reliable data would be from CUBE itself. I use this command to collect statistics for maximum connected calls "show call history watermark connected table" there is an option for cps as well - "sh call history watermark cps table ". The downside is that statistics is erased with every reboot. So to have it accurate for some period of time you will need to collect it periodically via script and store to some table or database. Then you can build report and have data for specific time range.   This is an example of output you can get:
11:25:30 AM Thursday Aug 11 2022 UTC
Connected Calls
------- The WaterMark Table for Second --------
_______________________________________________
Value : 0, ts : [Thu, 11 Aug 2022 11:25:25 GMT]
Value : 0, ts : [Thu, 11 Aug 2022 11:25:26 GMT]
Value : 0, ts : [Thu, 11 Aug 2022 11:25:27 GMT]
Value : 0, ts : [Thu, 11 Aug 2022 11:25:28 GMT]
Value : 0, ts : [Thu, 11 Aug 2022 11:25:29 GMT]
------- The WaterMark Table for Minute-------
Value : 1, ts : [Thu, 11 Aug 2022 11:15:18 GMT]
Value : 1, ts : [Thu, 11 Aug 2022 11:17:14 GMT]
Value : 1, ts : [Thu, 11 Aug 2022 11:17:18 GMT]
Value : 1, ts : [Thu, 11 Aug 2022 11:18:18 GMT]
Value : 2, ts : [Thu, 11 Aug 2022 11:02:53 GMT]
------- The WaterMark Table for Hour --------
Value : 3, ts : [Thu, 11 Aug 2022 08:33:17 GMT]
Value : 4, ts : [Tue, 09 Aug 2022 07:26:18 GMT]
Value : 4, ts : [Tue, 09 Aug 2022 07:55:18 GMT]
Value : 4, ts : [Tue, 09 Aug 2022 09:43:18 GMT]
Value : 4, ts : [Tue, 09 Aug 2022 11:38:18 GMT]
------- The WaterMark Table for Alltime------
Value : 6, ts : [Wed, 29 Jun 2022 07:54:41 GMT]
Value : 6, ts : [Tue, 19 Jul 2022 11:02:30 GMT]
Value : 6, ts : [Thu, 21 Jul 2022 09:05:29 GMT]
Value : 7, ts : [Mon, 20 Jun 2022 08:33:46 GMT]
Value : 8, ts : [Mon, 20 Jun 2022 11:33:46 GMT]
Hello John, I don't think you can get CPS statistics per direction on CUBE. Hopefully Cisco can improve this stat gap in the future.
Regarding the Alltime stats - it records top 5 values from the last boot, every time you reload the box you loose this statistics. That's why we parse this data periodically and build reports to see real load over CUBEs or gateways in time.
Connected Calls
Thank you Vladimir, It is showing Calls per second which is kind of what I am looking for, my specific need is CPS outbound only. Is there a way to get that? Here are the stats from one of the them, not clear what the the TS is for alltime?
Calls Per Second / CPS
Value : 10, ts : [Thu, 11 Aug 2022 20:06:36 GMT]
Value : 11, ts : [Thu, 11 Aug 2022 20:06:24 GMT]
Value : 11, ts : [Thu, 11 Aug 2022 20:06:34 GMT]
Value : 12, ts : [Thu, 11 Aug 2022 20:06:17 GMT]
Value : 14, ts : [Thu, 11 Aug 2022 20:05:47 GMT]
Value : 24, ts : [Thu, 11 Aug 2022 19:26:16 GMT]
Value : 24, ts : [Thu, 11 Aug 2022 19:28:43 GMT]
Value : 25, ts : [Thu, 11 Aug 2022 19:51:45 GMT]
Value : 26, ts : [Thu, 11 Aug 2022 20:01:13 GMT]
Value : 28, ts : [Thu, 11 Aug 2022 20:04:04 GMT]
Value : 27, ts : [Tue, 09 Aug 2022 13:45:03 GMT]
Value : 28, ts : [Wed, 10 Aug 2022 18:50:03 GMT]
Value : 28, ts : [Wed, 10 Aug 2022 17:03:03 GMT]
Value : 42, ts : [Thu, 11 Aug 2022 18:06:03 GMT]
Value : 43, ts : [Wed, 10 Aug 2022 18:04:03 GMT]
Value : 120, ts : [Fri, 08 Jul 2022 17:19:02 GMT]
Value : 134, ts : [Fri, 01 Jul 2022 17:43:02 GMT]
Value : 168, ts : [Thu, 03 Feb 2022 15:21:01 GMT]
Value : 169, ts : [Fri, 28 Jan 2022 15:53:01 GMT]
Value : 239, ts : [Mon, 28 Mar 2022 17:57:01 GMT]
Thank you Vladimir!  Wow 239-CPS from my report- that's a huge stat.. good to know.
