10-03-2011 07:31 AM - edited 03-16-2019 07:17 AM
hi all
I have make some CP7975 to register to the CME (C2921 IOS Version 15.1(3)T),
after that, I found the phone can not go to the power save mode automatically, so I configured those commands,
telephony-service
service phone displayIdleTimeout 00:01
service phone displayOnDuration 00:10
service phone displayIdelTimeout 00:10
service phone daysDisplayNotActive 1,7
and now the phones can go to the power save mode automatically after some inactive timer.
but now I find other problem, phones can not Display on while a call is coming, I look for the cisco.com and google it, but got nothing about it. I can not find the command to change the status of the phone from disable to enable.
so can anyone can help me or give me some advice?
thanks in advance !!!
Solved! Go to Solution.
10-03-2011 07:41 AM
Hi Yu,
Here we go
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html#wp1137696
Cheers!
Rob
10-03-2011 07:41 AM
Hi Yu,
Here we go
Cheers!
Rob
10-03-2011 08:54 AM
hi Rob,
you are so NICE, i will try it, +5 for you .
thanks.
yu.
