NME-CUE Problem with add language
Hi guys.
I'm trying add the language on NME-CUE but i receive the message :
Downloading ftp cue-vm-pt_BR-langpack.nmx.8.0.2.prt1
Bytes downloaded :  46690960
Validating package signature ... done
ERROR: Invalid package. Please verify if this is a valid package file.
I did dowload of 8.0.1, 8.0.2 and 8.0.5 version 10 times, I check the MD5 in all times and in all times the MD5 was validated.
Peterson
Aaron Harrison
Hi Peterson
From the same page you downloaded the language pack, there is a .pkg file (package file) called cue-vm-langpack.nmx.8.0.5.pkg - you need this and the file you have on your FTP server. Point CUE at the pkg, and then it will find the .prt1 file it needs when you select the language you want to install.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
5 Replies 5
Aaron Harrison
Hi Peterson
Aaron
Perfect Aaron.
+5 points to you!
Sorry for "beginner querstion"
Rob Huffman
Hi Peterson,
Hope all is well my friend
Here is a related thread where you will see what we determined the
issue to be;
https://supportforums.cisco.com/message/1153903#1153903
Cheers!
Rob
EDIT: +5 Aaron....you rock buddy!
Hi Rob.
I'm very fine and you?
Thanks for your reply.
When you come to Brazil
Rob Huffman
Hey Peterson,
Life is great here
I wish I was heading your way today ....it's -3 here this morning
brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr!!
Cheers!
Rob
