How to check active users information from dirsync logs
Yenosh
Is there any way we can check from the RTMT logs on how many users are active LDAP synced in cucm from logs
5 Replies 5
Very likely you can see that in the DirSync logs.
Response Signature
Yenosh
Thank you, can we also check the total LDAP user information from dirsync logs for specified time.
Why don’t you check and see what information is available?
Response Signature
From the logs I can only see connection failure message to LDAP server
Does your sync even work at all? You should not see connection failure message to LDAP server(s) if you have a working setup.
Response Signature
