How to check CUBE license session
Sanjay Bishnoi
I need your help to check out the CUBE license session and my part code is FL-CUBEE-5
Can you please help me out on this.
Thanks in Advance.
5 Replies 5
Jitender Bhandari
Hi Sanjay,
CUBE license are paper licenses which means you dont install it on the device itself, So there is no CLI command to double check the session.
Are you interested in knowing how many simultaneous SIP session you router can handle?
JB
Hi Sanjay -
Here are a couple of helpful IOS commands for you CUBE stuff.
You can set the license capacity in the Voice Service VOIP block
voice service voip
mode border-element license capacity 350 <-- your licensed session capacity
You can verify this
show cube status
CUBE-Version : 11.0.0
SW-Version : 15.5.2.T, Platform CISCO3945-CHASSIS
HA-Type : none
Licensed-Capacity : 350
Consider using a call treatment setting to ensure you don't exceed the SIP trunk capacity (bandwidth or session count) you've set up with your service provider.
call treatment on
call threshold global total-calls low 233 high 238
Verify the session capacity of your ISR
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/data-sheet-c78-729692.html
Chris Deren
FL-CUBEE-5 entitles you to 5 concurrent SIP sessions, though as stated you don't apply it anywhere.
santosnun
My question is different:
- The CUBE licnese applies only to IP2IP Gateway only or it applies also in IP2ISDN scenarios?
Table 1.             Cisco Unified Border Element Features
Feature
Support details
Protocols
●  H.323 and SIP
Protocol and signal interworking
●  H.323 to H.323 (including Cisco Unified Communications Manager)
●  H.323 to SIP (including Cisco Unified Communications Manager)
●  SIP to SIP (including Cisco Unified Communications Manager and Cisco TelePresence ®)
https://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/data-sheet-c78-729692.html
java
if this helps, please rate
