10-26-2015 05:40 AM - edited 03-18-2019 11:41 AM
Hi everybody,
I'm working on CUCM 9, I need to check registration log for a CIPC remotely for an investigation that I'm conducting.
Can you, guys, show how to check the registration log of a cisco IP phone?
Thanks in advance
10-26-2015 06:23 AM
Hi Amine.
On CUCM cli you can use show risdb query phone to show the phone status registration and the last transition timestamp
Regstatus is the actual registration status of the phone and RegStatusChgTimestamp is the date and time when the phone passed from a status of unregistered to registered or viceversa.
Carlo
10-29-2015 04:56 AM
I managed to enter the CLI command but I couldn't find the location of the log file created by this cmd.
Can you show me where can I find it and how, please ?
Thanks in advance, Carlo
10-26-2015 04:35 PM
In addition to what Carlo mentioned, you can go to CUCM, search for the relevant phone, click its IP address in CUCM which opens the web pages of the phone itself. This will also give you a log (although it is sometimes a bit cryptic).
good luck
10-29-2015 04:54 AM
Thank you Dennis for the tip ;)
10-28-2015 04:48 AM
Hi Amine
You can look at collecting logs thru RTMT. I would recommend you to download them and then login to RTMT > Double click on the Trace and log central and look up for the event viewer - Application log and Event viewer-System log. you can troubleshoot the IP Phones and IP communicators being unregistered.
Once you have collected them you can see them in Notepad++ using a searching criteria equal to the device name and also the timeframe when the problem happened.
You can also collect them from the SysLog Viewer> Expand Application Logs > then Cisco Syslog, you can see it from there if there's a specific timeframe.Still you can download them when you click on "Save"..
Once you got the information you will see message similar to this - with Device name and Device unregistered status.
Apr 25 13:01:22, JAMES-CCM-1, Error, Cisco CallManager, ccm: 9889781: Apr 25
17:01:22.231 UTC : %CCM_CALLMANAGER-CALLMANAGER-3-DeviceUnregistered: Device
unregistered. Device name.:SEP0024975A58DE Device IP address
[Optional].:10.34.192.135 Protocol.:SCCP Device type. [Optional]:365 Device
description [Optional].:8WDN 10 Reason Code [Optional].:13 Device MAC
address [Optional].:0024975A58DE IPAddressAttributes [Optional].:0 Cluster
ID:StandAloneCluster Node ID:JAMES-CCM-1, 14
Also for troubleshooting IP Phone Registration, using Status Messages and CUCM/Phone Logs collection and Trace/Logs reading
I would recommend you to go thru the below videos which are really helpful
https://supportforums.cisco.com/video/12212291/troubleshooting-ip-phone-registration
https://supportforums.cisco.com/blog/12088286/troubleshooting-ip-phone-registration-cucm
Lavanya
10-29-2015 04:53 AM
Thank you Muthurani for your very helpful answer.
10-29-2015 05:00 AM
Amine,
Im using wireshark application installed on windows. connecting the pc to our voice network and configuring port mirror on cisco switch that connecting the CUCM. its handy, you can filter log of ip phones based on ip address.
05-12-2020 02:38 AM
Try the tool from this website. It seems pretty good and can fetch the IP phone status along with the IP address.
05-12-2020 02:37 AM
