Hello all!
I've a 2800 series router running CCME 7.1 and i'm trying to get a SPA 502G IP Phone up and running. The phone obtains the correct IP configuration but does not register. I did change from scsp to sip using the menu button of the phone, and a i've done the basic config for sip on the router, similar to the following
voice service voip
allow-connections sip to sip
sip
registrar server
voice register global
mode cme
source-address 192.168.1.254 port 5060
max-dn 12
max-pool 12
voice register dn 1
number 1234
allow watch
name 1234
voice register pool 1
id mac 001B.FC57.6FEF
number 1 dn 1
dtmf-relay rtp-nte
username 1234 password 1234
codec g711ulaw
I don't know if something is missing, or if i need to do a basic setting on the phone, or maybe i should do something related to the firmware. If anyone could help, i will appreciate it. Thanks
