how to configure 3900 router as CME & VGW using SIP ?
essam_farrag
Hello Dears ,
we have Cisco router 3900 series and i need to configure this router as Call Manager Express to control SIP IP Phones.
this router has E1 circuit to provide PSTN connection.
is there any limitations of using SIP protocol for PSTN connectivity and IP Phones registration ?
knowing that i will configure CME features like (call pickup, transfer, forward, hunt pilot, intercom, paging, B-ACD, & FAC)
thanks
essam
Jaime Valencia
No, there is no problem with having the same ISR as CME and GW with TDM/SIP
java
if this helps, please rate
thanks a lot Jaime ,
would you please share with me any document for TDM/SIP VGW configuration with CME?
Best Regards.
Essam
The configuration doesn't change because this has CME, you use the regular CME admin guide, and the SIP trunk/TDM will depend on what your telco provides, there are plenty of examples on CSC and cisco.com, have you reviewed any documentation???
java
yes i have downloaded the admin guide
thanks a lot
Essam
