How to configure a CUCM-Cluster -- CUBE --- CUBE CUCM-Cluster?
mmantz
We want to connect our two cucm-clusters via cubes. I have tested SIP and H323. Both works fine. But we would like to have one feature: CALLBACK. Now i tried a intercluster-trunk using qsig, but this does not works with the cubes.
CUCM-Version: 7.1.5
Cube-Router:2911 Version: ADVENTERPRISE15.1(3)T
Best Regards
Are you able to share the configuration for connecting two CUCM via CUBE using SIP.  What is your reasons for putting CUBE between the two CUCM clusters?
putting in the Cubes is because of  security reason. In between are also to firewalls:
Cluster A ---Cube--FW----FW--Cube Cluster B
We only added firewal roles are to permit the cubes....
I do not have the configs...
Best Regards
