How to configure c3640 or vg204 to connect to VOIP service similar to SPA112
davidmillsom
Can a cisco 3640 with and FXS card or a VG204 be configured to connect to a VOIP service
in the same way as with an SPA112 ?
The answer will be based on the type of voip  service which  are you going to use?
Response Signature
Do you mean the distinction between being a trunk or just a phone?
In my case it is not a trunk but only a service to a cisco sipura box that has
ethernet on one side and an RJ11 on the other to which takes a
regular analog phone.
It is the same service as Vonaage.
