How to configure Cisco 8861 for Asterisk
arunmistry0510
I have Cisco 8861 phone, how to configure this for Asterisk:
Load: - sip88xx.11-7-1-17
Arun Mistry
11 Replies 11
bijpraka
sip88xx.11-7-1-17 are for Enterprise phones. You should be using MPP (3PCC) phones if you want to register to Asterisk. I would suggest getting it replaced with the right SKU.
You can find the right model here: https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-738030.html?cachemode=refresh
Look for Table 5 under Ordering Information.
Thanks.
Thank you for reply.
I have checked the list:
CP-8861-3PCC-K9=
Cisco IP Phone 8861 shipped with multiplatform phone firmware
Just need help to upload the SIP configuration in the phone.
Do you mean the phone you have is already "CP-8861-3PCC-K9="
What is the current software version on the phone?
Thanks.
Active load is - SIP88xx.11-7-1-11
Model No :- CP-8861
This is an Enterprise firmware. You will have to replace the phone with the 3PCC version - "CP-8861-3PCC-K9="
Thanks.
Can we change the firmware, as we do for Cisco 7940 and 7960
No. Enterprise to MPP (3PCC) or the other way is not supported as of now.
Thanks.
Jaime Valencia
You can, but it will be the hard way, as you don't have a 3PCC model which has a nice GUI where you can enter all the configuration for the registration with your 3rd party PBX.
Since you have an enterprise phone, which is meant to used with CUCM, you will need to manually format and provide the phone with the configuration files that it would expect from CUCM, there are plenty of threads at CSC and google you can use as reference.
I'd suggest you swap that phone you got, for the 3PCC variant.
java
if this helps, please rate
Thank you for support :)
Do you have Multi-platform firmware for any like - 8811, 8841, 8851 or 8861, from Cisco website is giving error for download.
I got some solution to upgrade the phone firmware.
Find attached download error.
Arun Mistry
I just tried downloading the MPP FW for 8841 and had no issues
java
