How to configure Cisco IP Phone without CUCM?
dennislung
Hi All
At first, I never use Cisco ip phone ever...
I just bought 2 used Cisco ip phone and already upgrade FW to ver. 9-4-2-SR3.
When I try to setting some configurations(some like disable LLDP, setting LLDP Power priority or QoS setting...),
it just can't be edit, even I was unlocked settings(**#).
I know this setting can change from Cisco Unified Communications Manager(CUCM), but I just can't download it...
So...is anyone can tell me how to setting this configurations without CUCM?
9 Replies 9
Leo Laohoo
Start by telling us what the exact models of the phone.
My IP Phone model is Cisco IP PHONE 7961g, thank you!
7961G?
Do you have a VoIP service provider?
Hi Leo
I do have a Cisco L3 switch but is there any relations to VoIP service provider and the ip phone manually configuration?or the ip phone can't be manual setting because of my VoIP service setting goes wrong?
What's the objective if the phone gets configured and no one can even make/take any calls?
Hi Leo
Just want to try some PoE and LLDP feature on the switch for now...
Ok, have fun.
Thank you Leo!!!
dennislung
My IP Phone model is Cisco IP PHONE 7961g, thank you.
