How to configure the dialed digit length in Cisco Call Manager
Nitin Kapoor
Dear All,
I just started to work in Cisco Call manager. currently the problem i am facing that whenever i dial any number from my cisco ip phone then its striping 1 digit somehow.
I checked the running configuration and i have  doubt if the below configuration have something to do with this. As if i am dialing any call with below pattern then its coming as 31 digit, but when i trace the call which is coming out from CME its only coming with 30 digit.  So somehow CME is striping 1 digit.
voice register global
mode cme
source-address X.X.X.X port 5060
max-dn 30    <====================
max-pool 30
authenticate realm X.X.X.X
tftp-path flash:
create profile sync 0029750544504382
Can anyone please help me to under this? And how can i fix this to make it more then 30 digit and it should not strip 1 digit?
Thanks in advance.
Nitin Kapoor
8 Replies 8
Ryan Huff
Level 4
Level 4
Hello Nitin,
Can you show me the "Voice-translation" and "dial-peer" sections on the CME configuration and also the FULL called number (number you are dialing)? With a modern router code level you could also just capture the output of "sh run | sec voice-translation|dial-peer".
Ryan
Hi Ryan,
Thanks a lot for your reply. Below is the dial peer configuration.
I am dialing as from my Cisco IP Phone
XXXXX (5 Digit prefix) configured on my Sonus switch + 8 Digit Prefix (Configured on my Sonus Switch for internal routing) + XXXXX (Prefix which associated to termination trunk on sonus) + 13 Digit China Number ( which is international call to me)
(this is how call work in my network) But if follow this call then i need to dial only
I need to dial always "7" first if i dial by using the configured prefix if i follow this pattern.
5+8+5+13 = 31 Digit
dial-peer voice 300 voip
session protocol sipv2
incoming called-number 3..
codec g711ulaw
no vad
dial-peer voice 7 voip
translation-profile outgoing sonustest
destination-pattern 7T
session target ipv4:X.X.X.X
voice-class codec 100
voice-class sip profiles 1000
dtmf-relay rtp-nte
clid strip name
no vad
dial-peer voice 8 voip
translation-profile outgoing nextonetest
destination-pattern 8T
session target ipv4X.X.X.X
dtmf-relay rtp-nte
clid strip name
dial-peer voice 109 voip
description ***USA Calls***
translation-profile outgoing local
destination-pattern 91..........$
dtmf-relay rtp-nte
clid strip name
no vad
dial-peer voice 110 voip
description ***International Calls***
translation-profile outgoing International
destination-pattern 9[2-9]T
dtmf-relay rtp-nte
clid strip name
no vad
dial-peer voice 100 voip
destination-pattern 100
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 999 pots
description *** Inbound Calls ***
translation-profile incoming incoming
incoming called-number .
direct-inward-dial
dial-peer voice 200 voip
destination-pattern 2..
codec g711ulaw
no vad
dial-peer voice 500 voip
destination-pattern 5..
codec g711ulaw
no vad
dial-peer voice 400 voip
incoming called-number 4..
codec g711ulaw
no vad
dial-peer voice 71 voip
translation-profile outgoing sonustest-g711
destination-pattern 71T
voice-class codec 101
clid strip name
no vad
dial-peer voice 81 voip
translation-profile outgoing nextonetest-g711
destination-pattern 81T
dtmf-relay rtp-nte
clid strip name
dial-peer voice 1800 pots
trunkgroup ATT_PRI
description ***Toll-Free Calls***
destination-pattern 91800.......$
forward-digits 11
dial-peer voice 1844 pots
trunkgroup XXX_PRI
destination-pattern 91844.......$
forward-digits 11
dial-peer voice 1855 pots
trunkgroup XXX_PRI
destination-pattern 91855.......$
forward-digits 11
dial-peer voice 1877 pots
trunkgroup XXX_PRI
destination-pattern 91877.......$
forward-digits 11
dial-peer voice 1888 pots
trunkgroup XXX_PRI
destination-pattern 91888.......$
forward-digits 11
dial-peer voice 101 voip
destination-pattern 101
codec g711ulaw
no vad
dial-peer voice 770 voip
translation-profile outgoing strip99
destination-pattern 99880$
codec g711ulaw
no vad
dial-peer voice 1 voip
destination-pattern 880
codec g711ulaw
no vad
dial-peer voice 99770 voip
destination-pattern 99770
codec g711ulaw
no vad
Nitin,
It would be much if you can take a debug for one of the test  so that we can isolate problem and why its happening.
Debug voice ccapi inout
debug voice translation
debug translation detailed
debug ccsip message ===if you you using sip connection
Br,
nadeem
PS: Please rate all useful post.
Br, Nadeem Please rate all useful post.
Can you also provide the voice-translation rule/profile section of the config? Specifically looking for the "local" and "international" translation profiles/rules.
Also, Are you dialing a 9 first?
Ryan
Hi Ryan,
Sorry for delay. Below is the requested information.
Building configuration...
Current configuration : 18077 bytes
! Last configuration change at 09:41:53 UTC Tue Jan 5 2016 by kingadmin
! NVRAM config last updated at 07:35:02 UTC Tue Jan 5 2016 by kingadmin
version 15.2
hostname CME
boot-start-marker
boot-end-marker
card type t1 0 0
logging buffered 2000000
no logging console
no logging monitor
no aaa new-model
network-clock-participate wic 0
ip cef
--More--
ip domain name yourdomain.com
no ipv6 cef
isdn switch-type primary-dms100
trunk group XXX_PRI
hunt-scheme round-robin
!4
quit
voice-card 0
dsp services dspfarm
voice service voip
ip address trusted list
ipv4 X.X.X.X
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/1
bind media source-interface GigabitEthernet0/1
registrar server
no call service stop
voice class codec 100
codec preference 1 g729r8
codec preference 2 g729br8
voice class codec 101
codec preference 1 g711ulaw
voice class codec 1
codec preference 2 g729r8
voice class codec 102
voice class sip-profiles 1000
request INVITE sip-header From modify "(From:)(.*<)\"" "\1 \"Test_Call \"<"
mode cme
max-dn 30
max-pool 30
tftp-path flash:
voice register pool 4
id mac 0000.0000.0000
number 1 dn 4
dtmf-relay rtp-nte sip-notify
voice-class codec 1
username 335 password lanoc^335
no vad
voice register pool 5
number 1 dn 5
voice-class codec 1
username 337 password lanoc^337
no vad
voice register pool 6
number 1 dn 6
voice-class codec 1
username 338 password lanoc^338
no vad
voice register pool 7
number 1 dn 7
voice-class codec 1
username 380 password r3m0t3380!
no vad
voice register pool 8
number 1 dn 8
voice-class codec 1
username 339 password gUSwu2ab
voice register pool 9
number 1 dn 9
voice-class codec 1
username 336 password lanoc^336
no vad
voice hunt-group 1 parallel
final 507
list 311,313,315,316,317,338,319
timeout 18
pilot 401
voice translation-rule 7
rule 1 /7\(.*\)/ /04593887\1/
voice translation-rule 8
rule 1 /^8/ //
voice translation-rule 71
rule 1 /71\(.*\)/ /04593887\1/
voice translation-rule 81
rule 1 /^81/ //
voice translation-rule 99
rule 1 /^99/ //
voice translation-rule 100
rule 1 /9\(.*\)/ /04593\1/
voice translation-profile International
translate calling 101
translate called 100
voice translation-profile incoming
translate called 103
voice translation-profile local
translate called 102
voice translation-profile nextonetest
translate called 8
voice translation-profile nextonetest-g711
translate called 81
voice translation-profile sonustest
translate called 7
voice translation-profile sonustest-g711
translate called 71
voice translation-profile strip99
translate called 99
application
package callfeature
param long-dur-disc-cause 34
param long-dur-duration 120
param long-dur-action disconnect
param long-dur-call-mon enable
license udi pid XXXXXXXx sn XXXXXXXX
hw-module ism 0
hw-module pvdm 0/0
redundancy
controller T1 0/0/0
clock source internal
cablelength long 0db
pri-group timeslots 1-24
description ***Conencting to XXX_PRI***
no ip ftp passive
translation-rule 101
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address X.X.X.X 255.255.255.0
duplex auto
speed auto
interface ISM0/0
ip unnumbered GigabitEthernet0/0
service-module ip address X.X.X.X 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway X.X.X.X
ip address X.X.X.X 255.255.255.128
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn timer T310 35000
isdn incoming-voice voice
isdn map address . plan isdn type national
trunk-group XXX_PRI
no cdp enable
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash0:
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip route X.X.X.X 255.255.255.255 ISM0/0
ip route X.X.X.X 255.255.255.0 X.X.X.X
tftp-server flash0:DSP69xx.12-4-122-02-121029.zz.sgn
tftp-server flash0:cmterm-69xx-sccp.9-1-1-0.cop.sgn
tftp-server flash0:SCCP69xx.9-3-3-2.zz.sgn
tftp-server flash0:SCCP69xx.9-3-3-2.loads
tftp-server flash0:SCCP69xx.9-1-1-0.loads
tftp-server flash:SCCP69xx.9-1-1-0.zz.sgn alias SCCP69xx.9-1-1-0.zz.sgn
tftp-server flash:DSP69xx.0-0-0-4.zz.sgn alias DSP69xx.0-0-0-4.zz.sgn
tftp-server flash:BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
control-plane
voice-port 0/0/0:23
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm X.X.X.X identifier 1 version 4.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register confprof1
switchover method immediate
switchback method immediate
switchback interval 5
dspfarm profile 2 transcode
codec g711alaw
codec g711ulaw
codec g729ar8
maximum sessions 2
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
maximum sessions 2
codec g711ulaw
no vad
dtmf-relay rtp-nte
clid strip name
no vad
dtmf-relay rtp-nte
clid strip name
dtmf-relay rtp-nte
clid strip name
no vad
dtmf-relay rtp-nte
clid strip name
no vad
codec g711ulaw
no vad
direct-inward-dial
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
clid strip name
no vad
dtmf-relay rtp-nte
clid strip name
trunkgroup XXX_PRI
forward-digits 11
trunkgroup XXX_PRI
forward-digits 11
trunkgroup XXX_PRI
forward-digits 11
trunkgroup XXX_PRI
forward-digits 11
trunkgroup XXX_PRI
forward-digits 11
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:X.X.X.X expires 3600 port 5060 transport udp
gatekeeper
shutdown
telephony-service
sdspfarm units 2
sdspfarm transcode sessions 4
sdspfarm tag 1 confprof1
sdspfarm tag 2 transcode
conference hardware
no auto-reg-ephone
max-ephones 100
max-dn 50
ip source-address X.X.X.X port 2000
max-redirect 7
caller-id block code *67
timeouts interdigit 2
cnf-file location flash:
load 6921 SCCP69xx.9-1-1-0.loads
load 6941 SCCP69xx.9-1-1-0
load 6961 SCCP69xx.9-1-1-0.loads
time-zone 13
voicemail 99880
max-conferences 4 gain -6
web admin system name kingadmin secret 5 $1$3QQe$fLaNlA1IBgQoYRXdQSX4H0
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Jun 17 2015 12:32:55
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
privilege level 15
login local
transport input all
line vty 5 15
privilege level 15
login local
transport input all
scheduler allocate 20000 1000
end
Can you make a test call and capture the output of "debug voip ccapi inout"?
Ryan
Hi Ryan,
I collected the logs for the test call i made. As i can see GwCollectedCalledNumber=70410279022861372711974T. (Gateway only collected the number upto ***74, whereas we had 1 more digit (8613727119747) after this.
GwReceivedCallingNumber=319
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x0
MlppServiceDomainNW=0 (none)
MlppServiceDomainID=0
PrecedenceLevel=-1 (PRECEDENCE_LEVEL_NONE)
GENERIC:
SetupTime=17030581420 ms (12:44:54.597 UTC Tue Jan 5 2016)
Index=118822
PeerAddress=045938870410279022861372711974
PeerSubAddress=
PeerId=7
PeerIfIndex=65
LogicalIfIndex=0
DisconnectCause=10
DisconnectText=normal call clearing (16)
ConnectTime=0 ms (0)
DisconnectTime=17030605420 ms (12:45:18.597 UTC Tue Jan 5 2016)
CallDuration=00:00:00 sec
CallOrigin=1
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=137
TransmitBytes=2740
ReceivePackets=161
ReceiveBytes=3220
--More--
VOIP:
ConnectionId[0xEFFD3694 0xB2E011E5 0xB7788B95 0x3CB0E993]
IncomingConnectionId[0xEFFD3694 0xB2E011E5 0xB7788B95 0x3CB0E993]
CallID=187889
SessionId=0
CallReferenceId=0
CallServiceType=Unknown
RTP Loopback Call=FALSE
RemoteIPAddress=X.X.X.X
RemoteUDPPort=12592
RemoteSignallingIPAddress=X.X.X.X
RemoteSignallingPort=5060
RemoteMediaIPAddress=X.X.X.X
RemoteMediaPort=12592
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=rtp-nte
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
SessionProtocol=sipv2
ProtocolCallId=F44FC747-B2E011E5-B77D8B95-3CB0E993@38.98.54.20
SessionTarget=X.X.X.X
SafEnabled=FALSE
OnTimeRvPlayout=0
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=0 ms
LoWaterPlayoutDelay=0 ms
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CoderTypeRate=g729r8
CodecBytes=20
cvVoIPCallHistoryIcpif=0
MediaSetting=flow-through
CallerName=
CallerIDBlocked=False
OriginalCallingNumber=319
OriginalCallingOctet=0x0
OriginalCalledNumber=
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
TranslatedCallingNumber=4695217000
TranslatedCallingOctet=0x0
TranslatedCalledNumber=045938870410279022861372711974
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
GwOutpulsedCalledNumber=045938870410279022861372711974
GwOutpulsedCalledOctet3=0x80
GwOutpulsedCallingNumber=4695217000
GwOutpulsedCallingOctet3=0x0
GwOutpulsedCallingOctet3a=0x0
MediaInactiveDetected=no
MediaInactiveTimestamp=
MediaControlReceived=
LongDurationCallDetected=no
LongDurationCallTimerStamp=
LongDurationCallDuration=
Username=
PrecedenceLevel=0 (PRECEDENCE_LEVEL_NONE)
CPA Call History Parameters
CPA Event Status: DISABLE
GENERIC:
SetupTime=17030713600 ms (12:47:06.777 UTC Tue Jan 5 2016)
Index=118823
PeerAddress=319
PeerSubAddress=
PeerId=20009
PeerIfIndex=110
LogicalIfIndex=109
DisconnectCause=10
DisconnectTime=17030745800 ms (12:47:38.977 UTC Tue Jan 5 2016)
CallOrigin=2
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=224
ReceiveBytes=4480
TELE:
ConnectionId=[0x43183BB8 0xB2E111E5 0xB77E8B95 0x3CB0E993]
IncomingConnectionId=[0x43183BB8 0xB2E111E5 0xB77E8B95 0x3CB0E993]
CallID=187890
Port=50/0/9 (187890)
BearerChannel=50/0/9.0
TxDuration=4160 ms
VoiceTxDuration=4160 ms
FaxTxDuration=0 ms
NoiseLevel=0
ACOMLevel=0
SessionTarget=
ImgPages=0
CallerName=Nitin Kapoor
LongDurCallTimeStamp=
LongDurCallDuration=
TranslatedCallingNumber=319
GENERIC:
SetupTime=17030720200 ms (12:47:13.371 UTC Tue Jan 5 2016)
Index=118824
PeerSubAddress=
PeerId=7
PeerIfIndex=65
LogicalIfIndex=0
DisconnectCause=10
DisconnectTime=17030745800 ms (12:47:38.971 UTC Tue Jan 5 2016)
CallOrigin=1
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=224
TransmitBytes=4480
ReceivePackets=247
ReceiveBytes=4940
VOIP:
ConnectionId[0x43183BB8 0xB2E111E5 0xB77E8B95 0x3CB0E993]
IncomingConnectionId[0x43183BB8 0xB2E111E5 0xB77E8B95 0x3CB0E993]
CallID=187891
SessionId=0
CallReferenceId=0
RemoteUDPPort=6094
RemoteMediaPort=6094
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=47088994-B2E111E5-B7838B95-3CB0E993@38.98.54.20
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=20
CallerName=
Username=
GENERIC:
SetupTime=17030747100 ms (12:47:40.271 UTC Tue Jan 5 2016)
Index=118825
PeerAddress=319
PeerSubAddress=
PeerId=20009
PeerIfIndex=110
LogicalIfIndex=109
DisconnectCause=10
DisconnectTime=17030787320 ms (12:48:20.491 UTC Tue Jan 5 2016)
CallOrigin=2
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=645
ReceiveBytes=12900
TELE:
ConnectionId=[0x570FEE7B 0xB2E111E5 0xB7848B95 0x3CB0E993]
IncomingConnectionId=[0x570FEE7B 0xB2E111E5 0xB7848B95 0x3CB0E993]
CallID=187892
Port=50/0/9 (187892)
TxDuration=9160 ms
VoiceTxDuration=9160 ms
FaxTxDuration=0 ms
NoiseLevel=0
ACOMLevel=0
SessionTarget=
ImgPages=0
GENERIC:
SetupTime=17030753700 ms (12:47:46.871 UTC Tue Jan 5 2016)
Index=118826
PeerSubAddress=
PeerId=7
PeerIfIndex=65
LogicalIfIndex=0
DisconnectCause=10
CallOrigin=1
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=645
TransmitBytes=12900
ReceivePackets=659
ReceiveBytes=13180
VOIP:
ConnectionId[0x570FEE7B 0xB2E111E5 0xB7848B95 0x3CB0E993]
IncomingConnectionId[0x570FEE7B 0xB2E111E5 0xB7848B95 0x3CB0E993]
CallID=187893
SessionId=0
CallReferenceId=0
RemoteUDPPort=27422
RemoteMediaPort=27422
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=5B0039B9-B2E111E5-B7898B95-3CB0E993@38.98.54.20
SafEnabled=FALSE
OnTimeRvPlayout=4040
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=20
CallerName=
Username=
GENERIC:
SetupTime=17030875530 ms (12:49:48.707 UTC Tue Jan 5 2016)
Index=118827
PeerAddress=8572320591
PeerSubAddress=
PeerId=999
PeerIfIndex=76
LogicalIfIndex=14
DisconnectCause=10
DisconnectTime=17030937120 ms (12:50:50.297 UTC Tue Jan 5 2016)
CallOrigin=2
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0xA39C7B87 0xB2E111E5 0x88744C00 0x82954350]
IncomingConnectionId=[0xA39C7B87 0xB2E111E5 0x88744C00 0x82954350]
CallID=187894
Port=0/0/0:23 (187894)
BearerChannel=0/0/0.1
TxDuration=0 ms
VoiceTxDuration=0 ms
FaxTxDuration=0 ms
CoderTypeRate=None
NoiseLevel=0
ACOMLevel=0
SessionTarget=
ImgPages=0
CallerName=
Source tg label=XXX_PRI
OriginalCallingNumber=8572320591
OriginalCallingOctet=0x21
OriginalCalledNumber=2446965
OriginalCalledOctet=0xC1
OriginalRedirectCalledOctet=0xFF
TranslatedCallingNumber=8572320591
TranslatedCallingOctet=0x21
TranslatedCalledNumber=215
TranslatedCalledOctet=0xC1
TranslatedRedirectCalledOctet=0xFF
GwReceivedCalledNumber=2446965
GwReceivedCalledOctet3=0xC1
GwReceivedCallingNumber=8572320591
GwReceivedCallingOctet3=0x21
GwReceivedCallingOctet3a=0x80
DSPIdentifier=0/1:1
GENERIC:
SetupTime=17030875530 ms (12:49:48.701 UTC Tue Jan 5 2016)
Index=118828
PeerAddress=215
PeerSubAddress=
PeerId=200
PeerIfIndex=77
LogicalIfIndex=0
DisconnectCause=10
DisconnectTime=17030957130 ms (12:51:10.307 UTC Tue Jan 5 2016)
CallOrigin=1
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
VOIP:
ConnectionId[0xA39C7B87 0xB2E111E5 0x88744C00 0x82954350]
IncomingConnectionId[0xA39C7B87 0xB2E111E5 0x88744C00 0x82954350]
CallID=187895
SessionId=0
CallReferenceId=0
RemoteUDPPort=0
RemoteMediaIPAddress=0.0.0.0
RemoteMediaPort=0
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
tx_DtmfRelay=inband-voice
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=A39DB46F-B2E111E5-B78F8B95-3CB0E993@38.98.54.20
SafEnabled=FALSE
OnTimeRvPlayout=0
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CoderTypeRate=g711ulaw
CodecBytes=160
AlertTimepoint=-148993544 ms (12:49:48.811 UTC Tue Jan 5 2016)
CallerName=
OriginalCalledNumber=215
GwOutpulsedCalledNumber=99770
GwOutpulsedCalledOctet3=0xC1
GwOutpulsedCallingNumber=8572320591
GwOutpulsedCallingOctet3=0x21
GwOutpulsedCallingOctet3a=0x80
GwOutpulsedRedirectNumber=215
GwOutpulsedRedirectOctet3=0x0
GwOutpulsedRedirectOctet3a=0x80
Username=
GENERIC:
SetupTime=17030930340 ms (12:50:43.515 UTC Tue Jan 5 2016)
Index=118829
PeerAddress=319
PeerSubAddress=
PeerId=20009
PeerIfIndex=110
LogicalIfIndex=109
DisconnectCause=10
DisconnectTime=17030964710 ms (12:51:17.885 UTC Tue Jan 5 2016)
CallOrigin=2
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=343
ReceiveBytes=6860
TELE:
ConnectionId=[0xC447855D 0xB2E111E5 0xB7908B95 0x3CB0E993]
IncomingConnectionId=[0xC447855D 0xB2E111E5 0xB7908B95 0x3CB0E993]
CallID=187896
Port=50/0/9 (187896)
TxDuration=3100 ms
VoiceTxDuration=3100 ms
FaxTxDuration=0 ms
NoiseLevel=0
ACOMLevel=0
SessionTarget=
ImgPages=0
GENERIC:
SetupTime=17030936940 ms (12:50:50.119 UTC Tue Jan 5 2016)
Index=118830
PeerSubAddress=
PeerId=7
PeerIfIndex=65
LogicalIfIndex=0
DisconnectCause=10
DisconnectTime=17030964710 ms (12:51:17.889 UTC Tue Jan 5 2016)
CallOrigin=1
ReleaseSource=1
ChargedUnits=0
InfoType=speech
TransmitPackets=343
TransmitBytes=6860
ReceivePackets=366
ReceiveBytes=7320
VOIP:
ConnectionId[0xC447855D 0xB2E111E5 0xB7908B95 0x3CB0E993]
IncomingConnectionId[0xC447855D 0xB2E111E5 0xB7908B95 0x3CB0E993]
CallID=187897
SessionId=0
CallReferenceId=0
RemoteUDPPort=11914
RemoteMediaPort=11914
SRTP = off
TextRelay = off
Fallback Icpif=0
Fallback Loss=0
Fallback Delay=0
RoundTripDelay=0 ms
FastConnect=FALSE
AnnexE=FALSE
ProtocolCallId=C837D338-B2E111E5-B7958B95-3CB0E993@38.98.54.20
SafEnabled=FALSE
OnTimeRvPlayout=3040
Transcoded : No
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
VAD = disabled
CodecBytes=20
CallerName=
Username=
Hi Ryan,
Actually i follow the above procedure i mentioned i dont dial 9. I have to dial 7 first and then dial the prefix (For example 7+04XXX+79XXX+China Number).
And if i dial with all this prefix, then i need to dial 9 only. Which do not accept any prefix.
