How to connect Cisco IP-Phones to a 4G LTE Network?
howkudyou
Hello!
I would like to ask if anyone could tell me how I can use a Cisco 2911 with an EHWIC-4G-LTE-G to connect IP-Phones to a 4G Network? I want to be able to call my mobile phone from a Cisco IP-Phone connected to the callmanager on the 2911 Router.
I was only able to find configuration samples to use the 4G connection for normal data and not for Voice Traffic.
I hope someone can help me.
Kind regards
George Sotiropoulos
Can you please clarify if there is on your enviroment a CUCM Server or if the telephony is solely managed by a CUCMExpress ie, by the Voice Telephony Service on the Router?
If it is the second, then you will need to do some reading on CME Configuration examples:
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-express/211270-Basic-Configuration-Guide-for-CUCME-CME.html
Hope this helps,
George
Hope the above helps,
gsotirop
