How to connect VG350 with CUBE 4431
mohammad saeed
Level 5
Level 5
Hi Guys,
I will have in project VG350 connect 400 analog phones then I have CUBE 4430, How to connect VG with CUBE and if there is any document explain this scenario with configuration.
6 Replies 6
They are separate units. Are you using cucm for vg endpoints or cme? From
cucm or cme u can create a sip trunk or sip dialpeer to cube to route
calls. For example, vg analog phones can register using sccp with cucm then
point a sip trunk to cube
Yes I have CUCM.
So you mean both will be register with CUCM!
How about the analog phones connect with VG350, will be manage in VG350 not from CUCM?
When you say manage, no you cannot MANAGE VG350 from CUCM. You can configure and make changes on CUCM and then push them to VG if you are using either SCCP or MGCP. You will still need to do initial configuration on the VG in terms of IP address, call agent, config server etc -
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/42101-cm-cfg.html
VG350 is independent unit. It will act as relay between analog phones and
cucm. It will present analog to phones to register to cucm as sccp phones.
So I will be able to see the 400 analog phones and manage them SCCP phones?
Thanks in advance for your support
Absolutely.
