How to create contacts/directory for 9971 on CME
rlaudiano
Hi, I have a 9971 on a CME 8.6 and I was wondering what is an easy way to add contacts to the phone, local directory or on the CME or an external server. My contacts button doesn't show anything, it's just blank.
Ridney
HI
sorry find the below:-
url directory http://ip address of the CME/localdirectory
no create profile
create profile
please rate all useful information
9 Replies 9
islam.kamal
Level 10
Level 10
can you try under "voice register global" the following?.
no create profile
create profile
hi islam.kamal, the http option is not available on my router
UC520(config-register-global)#?
voice register global configuration commands:
  application              Define application
  apply-config             apply config for the 99/89 phones, restart all other
                           sip phones
  attempted-registrations  Define size of the attempted-registrations table
  authenticate             Define auth mode for SIP CME/SRST
  bandwidth                allow SIP SDP bandwidth related options
  bulk                     Define a pattern for bulk registration
  call-feature-uri         Define TNP SIP phone's Call Feature URI
  call-forward             Decide call forward parameters for an SIP phone
  camera                   Enable camera
  create                   Create profile for SIP phone
  date-format              Set date format for IP Phone display
  default                  Set a command to its defaults
  dialplan-pattern         Define E.164 telephone number prefix
  dst                      Enable / define daylight saving time
  exit                     Exit from voice register global configuration mode
  external-ring            Set external ringing to be included into alert-info
  fac                      Voice register global FAC setup
  file                     Enable generation of the text profile
  forwarding               Decide if forwarding local is enabled for SIP phone
  hold-alert               Enable On-Hold alert for SIP phone
  ip                       Set ip packet options
  load                     Select the firmware load file
  logo                     Define logo url that will be used by SIP phone
  max-dn                   Define max number of dn
  max-pool                 Define max number of pool
  mode                     Define mode: CME/SRST
  mwi                      Generate stutter tone for SIP mwi
  network-locale           Define network locale
  no                       Negate a command or set its defaults
  ntp-server               Define NTP server address for TNP phones
  outbound-proxy           Configure an Outbound Proxy Server
  overlap-signal           Configure Overlap Signaling support
  phone-redirect-limit     Define max number of redirect per call for SIP phone
  privacy                  Enable privacy for SIP shared-line phone
  privacy-on-hold          Enable privacy-on-hold for SIP shared-line phone
  reset                    Reset all SIP phones
  restart                  restart all SIP phone
  source-address           Define IP address and port for SIP CME
  tftp-path                Define tftp path for SIP CME
  time-format              Set time format for IP Phone display
  timeouts                 Define timeout value for sip phone
  timezone                 Set timezone for SIP Phones
  upgrade                  Generate OS79XX.TXT for firmware upgrade
  url                      Define SIP phone URL's
  user-locale              Define SIP Phone user locale
  video                    Enable video
  voicemail                Set the voicemail access number called when the
                           messages button is pressed
It is
Suresh
HI
no create profile
create profile
thanks, i will give this a try on the weekend and will let you all know.
rlaudiano
hi, i have finally made the contacts button work. now it has local directory, local speed dial and another line in there i just can't remember. however, i can't find a way to add contacts either from the phone or from the router except for local speed dial. is there a way to add contacts to this local directory?
Go to telephony-service in cme and make entry like below..
directory entry 1 PHONE_NUMBER name XYZ
directory entry 2 PHONE_NUMBER1 name XYZ1
Suresh
thanks, that is correct. the problem i had was that i used the wrong ip address under http://x.x.x.x/localdirectory which should have been my loopback address as i had tftp sourced using loopback. changed to the correct ip address and now i can search for all the contact entries under local directory. thanks
Battling to get my 9971 to register to my 2811 CME. I had it registered and working but a power failure put a stop to it. I have tried everything I can think of and it just won't register.
Debugs show the phone registering and deregistering every minute or so. CME seems to tell the phone to de-register due to privacy update.
Rlaudiano - Please can you post your router configure so that I can see where I might be going wrong. I also plan on setting up contacts so your config would be a really good resource.
Thanks.
