How to create two tftp server options 150 in windows 2008 R2
vitekabc1
Can anyone tell me  How to create two tftp server options 150 in  windows 2008 R2 DHCP servers ?
This is for TFTP redundancy and load balancing, so each phone can have two tftp server setting from the DHCP server.
You need to create the option as an array. See Step 2 of Adding the TFTP Option to the Scope for the blow-by-blow.
Please remember to rate helpful responses and identify helpful or correct answers.
Chris Deren
Use comma between the addresses.
vitekabc1
Hi Chris, the DHCP option entry looks like this , where can i use the comma ?
vitekabc1
Problem solved, thank you very much !
