03-13-2013 02:25 PM - edited 03-16-2019 04:15 PM
Has anyone customized GUI portal of Unity Connection Cisco PCA or CUCM ccmuser GUI ?
We have certain requirement where we want to disable specific functions for end users.
Thanks..
03-13-2013 03:05 PM
CCMuser you can configure what is available under enteprise parameters.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
03-14-2013 11:52 AM
Thanks Jamie!
Actually I am keen to see customization on Unity Connections web inbox. Looks like it is as standards as we see.
I thought somewhere should be an option, like we customize phone menu's.
Cheers,
