12-27-2011 06:23 PM - edited 03-16-2019 08:43 AM
Hi Expert
One requirement from client that is "Internal and external calls shall each be indicated by different, distinctive ringing patterns", anyone knows how to achive this on CUCM? i'm not using CME. Thanks!!!
Wish you, Happy Holiday!
Solved! Go to Solution.
12-27-2011 08:57 PM
If you mean you want ring A for internal and Ring B for external that's not possible, all you can do is change the cadence but you'll have to use the same ringtone.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-27-2011 08:57 PM
java
