IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6164 Views
  • 14 replies
I have a customer that wants a feature that i dont think CUCM can do but I wanted to run it by everyone for suggestion. The users wants the receptionist to be able to page him across the speaker phone if he is already on a call. Any help would be gre...
I have an issue that I cant quite find the answer to.  Say I have a 9971 with 6 lines configured.  A call comes in on my non-primary line and I answer it.  After I hang up that line is now the active line, not my primary line.  Is there a way to chan...
robloeber by Level 1
  • 475 Views
  • 2 replies
I have a UC560 and an ASA. I have a 7945 and have it connected remotely. It registers but there is no audio. I initially was trying to get the ASA to work with the UC Phone Proxy but it wasnt working.RIght now:I have a remote phone connected behind a...
Hello,I have call manager 8.x anyways I have a cisco 7961 phone that has 2 of the same extensions that a 7941 phone has.  The 7941 has two lines with the same extension.  When you call the 7941 phone and the first line is taking up, the 7961 phone li...
Hi,  I appreciate there are several discussion along this line already, however I have a H323 configured gateway on a CUCM for PSTN access, with an FXS Card used by Fax Machines which is controlled by MGCP. Reading the exiting posts I believe they de...
ian.ryder by Level 1
  • 666 Views
  • 2 replies
Hi,Basic call works fine, but does not work extension dial number (DTMF). Here's my scheme connections:                         SIP                                   H.323SIP Provider <-------------->GW(Cisco2821)<-------------->CUCM8.5.1Router confi...
