How to disable EnergyWise for all phones on CUCM !??
rfurukawasr3
Hello everyone, I have a problem, the IP phones are sending broadcast (43440 UDP port) every 30 seconds on voice vlan. I researched and discovered that is about "EnergyWise" feature, and we did not use this feature, on access switchs the feature EnergyWise are disable.
Through GUI phone interface I saw: Energywise Domain: "Net_123".  I tryed disable that funcion just on my phone for test on CUCM: Device > Phone and My ephone configuration on menu "Product Specific Configuration Layout" I check box (Override Common Settings) on that options:
*EnergyWise Domain
*Allow EnergyWise Overrides
After checked box (Override Common Settings) on these options above.the broadcasts on my phone are ceased. And on GUI phone interface I don't see any Domain setting.
After that solution only for my phone, I need to know how to disable this feature for all phones on CUCM, If when I disable that feature the phones are reset or restart???
Thanks so much !!!
Rajan
You need to configure this settings in Common phone profile
Device --> device settings --> Common phone profile
Apply it for all the required phones.
Rajan
Pls rate all useful posts
Rajan
Rajan
Thanks for your reply !!
There are another option for disable? My question is because after this post I see some configurations about EnergyWise on:
CUCM > System > Enterprise Phone Configuration:
EnergyWise Domain: Net_123                                     x (Override Common Settings)
EnergyWise Endpoint Security Secret: *********           x (Override Common Settings)
Phone On Time: 00:00
Phone Off Time: 24:00
My doubt is: On Enterprise Phone Configuration are setting the same Domain I saw on phone, I think is a "global" configuration, If I set Blank (erase domain and secret) on Domain and Security  Secret options, this apply for all ? This is another way option to disable EnergyWise?
Thanks so much for help me !
You can find more information on this feature in the below link:
http://docwiki.cisco.com/wiki/Configuration_and_Troubleshooting_Guide_for_Cisco_EnergyWise_Power_Save_Plus_Feature_on_IP_Phones#EnergyWise_Domain
Rajan
