09-07-2016 01:47 AM - edited 03-17-2019 08:03 AM
We have a standalone Prime ELM that is used to license a 2 node cluster CUCM1 and CUCM2
However, when I login to CUCM1 the initial page list the installed applications which show Prime License Manager, if I click the link it takes you to the Prime License manager originally installed with CUCM1
The same is true of CUCM2
I have to use the specific URL for ELM to get to the central Prime that we are using
How do I tidy up these links?
Solved! Go to Solution.
09-07-2016 05:44 AM
Hi David,
If you are running CUCM version 10.5.1.X and above you can remove it check below for detail
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/10_5_1/userguide/CPLM_BK_U9B156B7_00_user-guide-rel-1052.pdf
Search for "Remove Cisco Prime License Manager"
JB
09-07-2016 05:44 AM
Hi David,
JB
09-07-2016 05:48 AM
JB,
Very nice, I did not know that feature existed. +5 points.
09-07-2016 07:39 AM
Chris,
thanks for acknowledging.
JB
09-21-2016 07:47 PM
to add further, when u issue the command license management system remove from subscriber, server reboots.
After the server comes UP, u would get still get the Hyperlink for Prime License Manager. When u click on that, it would show the message
" Cisco Prime License Manager was removed from the server by system administrator on Tue May 21,2016. If you require any further assistance contact system administrator"
regds,
aman
09-07-2016 06:44 AM
That is exactly the answer I was looking for, I couldn't find references to it anywhere. Thanks Jitender!
09-07-2016 07:26 AM
Happy to help
JB
09-07-2016 05:46 AM
PLM/ELM is automatically installed on every CUCM, CUC, but the application can be managed by only one. There is no way to remove it you just ignore it on the other nodes and go to the one you configured.
