1.)Launch the Jabber client from your desktop by clicking on the icon. It should look like the following:
2.)Login to Jabber using your Active Directory / Network login credentials that you typically use to login to your computer.
3.)Towards the bottom left of the Jabber client, locate an icon that looks like the following:
4.)Click on the icon to bring up a menu and select “Use My Desk Phone for Calls”.
5.)Your icon should now change to one that looks as follows:
6.)Your Jabber client is now successfully setup to control your desktop phone.
