11-05-2015 06:45 AM - edited 03-17-2019 04:49 AM
I'm working on CUCM 9.1 and I want to establish a ssh/telnet session to a Cisco H.323 gateway.
Can you guys show me how to do this?
Thanks in advance, guys
Solved! Go to Solution.
11-05-2015 11:56 AM
Hi.
AFAIK CUCM doesn't have a ssh client.
If you are on a virtual environment, you can ssh to your esxi and from there smyou can ssh your gateway.
Carlo
11-05-2015 07:53 AM
H.323 gateway is not a special device rather a standard IOS. You need to follow the same process as with any standard Cisco router.
- Vivek
11-05-2015 07:57 AM
Can you give me the the cammand line that I should enter in CUCM (in CLI) to establish ssh/telnet
session.
Thanks, Vivek, fro the feedback
11-05-2015 08:00 AM
Why do you want to login from CUCM CLI?
Simply use PUTTY/Telnet and login to router. Isn't it?
- Vivek
11-05-2015 08:05 AM
It's not that simple, my pc can't ping the gateway, but I can ping the gateway from the CUCM CLI interface
that's why I'm asking if there is way to establish a telnet/ssh session from the CUCM into the gateway.
11-05-2015 11:56 AM
Hi.
Carlo
11-08-2015 12:02 PM
Thank you, Carlo, for your confirmation
