How to find allocated numbers within Call Manager for all sites
scorpio.besal
How do we find allocated numbers within Call Manager for all sites.
I want to prepare an Excel spreadsheet for all the allocated numbers.
Any help & guidance would be appreciated.
Jaime Valencia
That is something you need to do offline, CUCM has no idea of what your dial plan looks like, what ranges you assigned to each site, what is available, if it's a DID or not, etc.
All you could get out of CUCM, is what CUCM knows, because you configured it, and that would be either using BAT or via route plan report, it would be up to you to turn that into actual information, and not just a data dump.
java
if this helps, please rate
Thank you for your reply.
Is there any other way I can find allocated numbers.
You'd need to know what your dial plan looks like, and then map that info to the data dump from CUCM, then you'll see what you have configured and you can probably consider those as already allocated, this is going to require manual labor to turn a data dump into useful info.
java
Dennis Mink
You can go into route plan report in CUCM and do "view in file"
Please remember to rate useful posts, by clicking on the stars below.
