How to find the CUCM Serial Number: Version 6.1
Giovanni Ceci
Hey all,
I'm trying to call TAC about an issue, but I can't find the serial number of the CUCM. Usually on version 7.x, I go to OS Administration page >> Show >> Hardware and there it is. But it doesn't do this in version 6.x. I also tried show hardware on the CLI, but no good.
Does anyone know of a 'secret' way of finding it? (Other than looking at the physical box, of course! )
neocec
Rob Huffman
Hi neocec,
You are hitting this 6.x bug
CSCso99275            Bug Details
Show Hardware command does not show Serial number of server
Symptom:
'show hardware' from cli and gui does not display serial number of the server
Conditions:
CUCM 6.x and above. Issue does not exist with CUCM 5.x (GUI)
Workaround:
Use SNMP to find the serial number from the CLI:
-An SNMP community string (at least readonly) must be configured, if this hasn't already been done. The following doc discusses configuring a community string:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_0_1/admin/sasnmpv1.html#wp1063451
In the below example, the community string is "public".
-Use the following command from the CLI of the server you wish to find the serial number for:
(for HP servers)
utils snmp walk 2c public 127.0.0.1 .1.3.6.1.4.1.232.2.2.2.1.0
(for IBM servers)
utils snmp walk 2c public 127.0.0.1 .1.3.6.1.4.1.2.6.159.1.1.60.1.1.3.6.115.121.115.116.101.109
StatusStatus
Fixed
Severity Severity
3 - moderate
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified Communications Manager (CallManager)
Technology Technology
1st Found-In 1st Found-in
6.0
Fixed-In Fixed-in
7.0(0.39700.90)
6.1(2.9901.31)
7.0(0.66666.1)
7.0(0.66666.2)
7.0(1.11000.2)
7.1(0.98999.7)
6.1(3.1000.16)
6.1(3.9999.1)
Interpreting This Bug
Cheers!
Rob
Rob Huffman
Hi neocec,
Symptom:
Conditions:
Workaround:
(for HP servers)
(for IBM servers)
StatusStatus
Fixed
Severity Severity
3 - moderate
In Last Year
Product Product
6.0
Fixed-In Fixed-in
7.0(0.39700.90)
6.1(2.9901.31)
7.0(0.66666.1)
7.0(0.66666.2)
7.0(1.11000.2)
7.1(0.98999.7)
6.1(3.1000.16)
6.1(3.9999.1)
Cheers!
Rob
Rob, You're the Man!! Always helpful! That worked perfectly!
Thanks so much!
neocec
