How to generate a list of all DNs and registered phones
fred.weston
My org is presently running CUCM v10.5.2 on premise and is preparing to migrate our voice service to a cloud VoIP provider.  I am working to document our existing setup so it can be duplicated as much as possible.
Here are my questions.  Is there a way to generate a list of:
  1. All DNs, including the configured alerting name for each?
  2. All currently registered phones, including their DNs?
  3. All phones (including their DNs) that have been registered within a certain time period (i.e. all phones that were registered at some point within the past week)?
Jaime Valencia
1 Yes, use BAT, either lines or phone all details, play around with it and see what works best for you
2 Google "show risdb query phones" that's the closest thing you can get
3 No such report.
If you're trying to find devices which have not been "used" (ie made/received calls) if CAR/CDR is enabled you can generate the reports for a certain period of time, you'll see devices which have been active during that period of time, and anything not showing calls, has not been active.
java
if this helps, please rate
