how to get file license for cme2901 with FL-CME-SRST-5
essaki_ihssan
hi,
please can you help me to get the file license for CME 2901.
i have the license FL-CME-SRST-5 but i don't found the PAK numbre, so can you help me to get the file if there is an other way to get it.
thanks
Hi.
You don't need to register anything.
Just conserve the envelope shipped by Cisco.
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
7 Replies 7
Hi.
In your 2901 ,after an evaluation period, your licenses are modified in "Right to use".
The license you received doesn't need to be activated but it's only " honor" based
You can use this link as reference.
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1155517
Calo
Thanks Carlo for your quick answer,
but i have buy tow licence FL-CME-SRST-5 (10 count), and the evatuation licence is at 35 so if the licence change to "Right to use" i will get 10 or 35 licence count??
and if i will add some licence after how can do?
Best regards.
Hi ,
You can get FL-CME-SRST-X where X stands for 5, 25 and 100. It depends for how many users u are looking for.
The user license count takes summary of FL-CME-SRST-5/FL-CME-SRST-25/FL-CME-SRST-100.
regds,
aman
Hi.
After the evaluation period, your srst funcionality is still guaranteed, but "legally" you coud register only the number of licensed devices (in your case 10).
As I mentioned, those license are still honor based.
after the evaluation period how can i register my 10 count license?
Hi.
Carlo
I will save the envlope until the licence change to "right to use", if nothing change  i will resend it to cisco.
thanks Mr Carlo very mutch for you answer.
Regards.
