How to Get Incoming call number?
rtninfo23
Hello
What is the best way to get Incoming call number with C#?
TAPI 3.0? Jumlar ATAPI? Webdialer Soap? or Other?
Many Thanks
5 Replies 5
Aaron Harrison
It would depend on your experience and dev language.
If you need it 'live' (i.e. as the call arrives) then TAPI or JTAPI would be best. I prefer JTAPI as it doesn't require installation/config, you can download it and instantiate it through code.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thank you for you reply Aaron.
I need it live and I use Visual Studio 2010 tools and C# langage.
Are you some sample of code Java or C#  implemented that?
Todisoa
I have already an C# implementation but it doesn't work.
This is  my C# code.The CallStateChanged event  is not  occured.
  private TapiManager tapiManager = new TapiManager("InCommingCall");
tapiManager.Initialize();
TapiLine line = tapiManager.GetLineByName("H323 Line", true);
if (!line.IsOpen)
line.Open(MediaModes.InteractiveVoice);
line.CallStateChanged += new EventHandler(line_CallStateChanged);
     void tapiManager_CallStateChanged(object sender, CallStateEventArgs e)
            this.txtInfo.Text = this.txtInfo.Text + "Incomming Call number: " + e.Call.CallerId;
Todisoa
I just added a new code but always no event occured.
  line.NewCall += new EventHandler(line_NewCall);
Nobody? no Idea?
Todisoa
Wrong forum, try developer.cisco.com
