how to know all IP Phone that dos not have certificate?
Ahmed Tarek
Level 3
Level 3
hi all,
i need to know how to get all IP Phones in CUCM that dose not have certificate yet?
LSC:Not installed
5 Replies 5
Generate CAPF Report
If you want to do so, you can generate a CAPF report to view the status of the certificate operation, the authentication string, security profile, authentication mode, and so on. The report includes information such as device name, device description, security profile, authentication string, authentication mode, LSC status, and so on.
To generate a CAPF report, perform the following procedure:
Procedure
Step 1
In Cisco Unified Communications Manager Administration, choose Device > Phone.
The Find/List window displays. Records from an active (prior) query may also display in the window.
Step 2
To find all records in the database, ensure the dialog box is empty; go to Step 3.
To filter or search records
  1. From the first drop-down list box, choose a search parameter.
  2. From the second drop-down list box, choose a search pattern.
  3. Specify the appropriate search text, if applicable.
    Note
    To add additional search criteria, click the + button. When you add criteria, the system searches for a record that matches all criteria that you specify. To remove criteria, click the button to remove the last added criterion or click the Clear Filter button to remove all added search criteria.
Step 3
Click Find.
All matching records display. You can change the number of items that display on each page by choosing a different value from the Rows per Page drop-down list box.
Step 4
In the Related Links drop-down list box, choose CAPF Report in File; then, click Go.
Step 5
Save the file to a location that you will remember.
Step 6
Use Microsoft Excel to open the.csv file.
Response Signature
thanks Nithin, for your usual support,
i select from search LSC status and found the below points:-
1- image no 1 some IP Phones has pending upgrade
2-image no 2 some IP Phones has none LSC
3- image no 3 some IP Phones Upgrade Failed: User Initiated Request Late/Timedout
4-image no 4some IP Phones has Upgrade Success
5-image no 5 this i car generate PRT, what is PRT ? also i can`t find  CAPF Report
Ahmed Tarek
Level 3
Level 3
do anyone have update?
You already got the info from report.
Response Signature
thanks for your reply Nithin,
how can export to excel?
how can i installed all IP Phone certificate instead of one by one?
