How to make a list of DID by location?
mtotelenivel1
How can I make a list of DID grouped by location in CCM 4.3? Is it possible to do it using CCM web? Or I need to use SQL queries against database?
Victor
Jaime Valencia
Assuming you are talking about the location config in CUCM and you want a report of which DNs are in which location, you can do a BAT export all details and then just sort out them by location field.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks javalenc. I've made with BAT export and later with Excel and I has been I needed.
Best regards!
Victor
