How to register the sip phone 7821 to call manager (avaya ip office)
cromilla
Hi We are implementing Avaya IPO R10 part of the end points are cisco 7821 SIP Phone. Kindly help us how to register this to avaya IPO
adnan.alim
Level 5
Level 5
Hi Carlo,
  • You need 3rd Party IP Endpoint license in Avaya IP Office
  • You wont be able to put Avaya firmware in the Cisco phone
  • You need TFTP server to update the Cisco IP Phone firmware & settings files.
  • You need to modify certain settings as mentioned in the below links
  • Below links are for 79xx phones, but you can give a try....
https://www.devconnectprogram.com/fileMedia/download/8ce81a87-d315-4dbb-a164-759d79e93bb6
https://downloads.avaya.com/elmodocs2/sip/SES31BE_PP.pdf
Mark as answered, if it is helpful.
-Adnan
10 Replies 10
keglass
Level 7
Level 7
Carlo,
I recommend you search the Avaya support forum for more information.
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
adnan.alim
Level 5
Level 5
Hi Carlo,
-Adnan
Hi Adnan,
Thank you very much for this info.
Carlo
Hi Adnan,
Can you help us to find the firmware for third party call control.
These release notes support the Cisco IP Phone 7800 Series Third-Party Call Control running SIP Firmware Release 10.3(1).
The following table lists the support and protocol compatibility for the Cisco IP Phones.
Cisco IP Phone
Protocol
Support Requirements
SIP
Third-Party Call Control System
Table 1 Cisco IP Phones, Support, and Firmware Release Compatibility
Carlo
Hi Carlo,
As far as i know, there are 2 variants of Firmware available for 78/88XX phones. SIP Firmware & MPP (Multi platform), there is no specific 3rd party Firmware available.
MPP firmware is for Cisco MPP IP Phone series which can be registered directly to 3rd party Cloud Call Control like Broadsoft, Asterisk, MetaSwitch, RingCentral...
SIP Firmware is for Enterprise build Phones, which can be registered to CUCM, Cisco HCS, Webex Teams (Spark)..
-Adnan
Thanks Adam for the info.
Carlo
Thanks Adanan
I am currently stuck, but seeing your explanation is very helpful, maybe the 78xx type is not designed for other PBXs such as SIP propitary.
spazziani
Hi Cromilla,
What was the model of the phone that you could configure on the PBX, CP-7841-K9 = or CP-7841-3PCC-K9 =?
Hi @spazziani , the phone model that could be configured on the PBX with the designations CP-7841-K9 and CP-7841-3PCC-K9 is the Cisco IP Phone 7841. The "3PCC" in the latter model indicates support for third-party call control, making it suitable for environments using non-Cisco call control systems.
yohanes
I also have the same problem, but I plan to register with Avaya Session manager.
I am currently testing the CP-7821-K9= V04 type.
Previously I had converted to MPP but it didn't work,
maybe for type 78xx can not register to another PBX
