How to remove this annoying bubble?
matthewbertram
I use Jabber for work and I have to use multiple different tabs and this annoying bubble keeps getting in the way. I used Jabber during Windows 10 and it never popped up, but ever since switching to 11 it always pops up and I absolutely despise this little bubble. I tried going to view -> position docked window, but all the options are grayed out. How do I get rid of this?
click on setting button >> View >> uncheck "Show docked window" after that you must just close the app and reopen it again, no need to re-login, just close the Jabber window and open it again, the call bubble will disappear
in addition of what dear @Mohamed H. Abdelmotaleb  said,
you can also disable "Docked Window" by add this Jabber XML Option on CUCM, UC Profile, Jabber-Config.xml >>
Section: options
Parameter: DockedWindowVisible
Value: false
(Rate by "Helpful" or "Accept") (محمدرضا هادی_ایران) (Email: morez.hadi@gmail.com)
