How to resolve this error :SERROR: process_pri_simple: NO name in GTD
iantra123
Level 3
Level 3
We're using 4 E1 PRI for connecting with a Telecom Provider.
When debuging isdn error, we see this error :
The controller E1 show some errors :
70 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
70 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
14042 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
14042 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
The IOS is : c2800nm-advipservicesk9-mz.124-22.YB.bin
How to resolve these errore?
gogasca
Level 10
Level 10
There was a bug open for this "CSCeg53014" Viewable at:
cisco.com/go/bugs
This bug was junked. The following reason was given:
SERROR: process_pri_simple: NO name in GTD, is a informativae message it
does not affect any call processing. The message is for debugging
purpose. So, This is not a problem.
One issue is that this not service impacting and may be considered a feature request and not a bug
The bugs is classified as a low severity bug and I recommend you to track the
progress via the bug id. In last august there was a discussion within DE team in regards this so please go ahead and check the progress of the bug i believe in around 2 months you may get some news.
paolo bevilacqua
As others mention, it is a cosmetic issue, instead you should upgrade to YB4, and configure network-clock-select 1 e1 0/0/x to eliminate the many slip errors.
