07-15-2015 11:09 AM - edited 03-17-2019 03:39 AM
I need help for setting up Unity for Holiday Recording
07-15-2015 11:20 AM
How is your current call flow going? Can you describe your setup.
08-05-2015 07:59 PM
I did the following but still not working need help
1. Unity Voice mail - Add a new Holiday
2. Call in during the test and report the result .
3. U VM - Call Management - System call Handlers- Opening Greeting - Edit - Greetings then check the Holiday Boxs .
4. U VM - Enable (Greeting Enabled with No End Date and Time ).
5. U VM - Callers Hear - check ( System Default Greeting ) 6. U VM - After Greeting -Call Handler - Operator
08-05-2015 09:25 PM
Did you assign the holiday to a schedule and did you assign the schedule to the system call handler
08-05-2015 09:36 PM
Yes I did set holiday to schedule , But I used the Weekdays schedule and from the Call handler I have opening Greeting
and I made Weekdays is the Active Schedule .
Stiil not working
08-05-2015 09:43 PM
There is any way we can test that
07-15-2015 12:12 PM
You are going to need to do more leg work than that. A one line sentence isn't going to get you much, if any help.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/administration/guide/10xcucsagx/10xcucsag080.html#pgfId-1140219
07-15-2015 12:24 PM
Unity has been setup for Holiday but sometime working sometime not.
07-15-2015 12:34 PM
Please go to user /system call handler edit >> greeting >> enable holiday greeting (chose personal recording)
step 2 >> System Settings >>Holiday Schedules (add all the necessary holidays)
step 3 >> user /system call handler >> Active Schedule >> view >>choose correct Holiday Schedule from step 2
try it and let us know how it go
Thanks and Regards
Raman
07-15-2015 01:52 PM
There is no greeting under system call handlers , should I create one , I have Operator , openning greeting , Goodye,
07-15-2015 02:01 PM
you should set the holiday greeting for you main auto attendant ..
if there is no call handler you should set the holiday greeting for opening greeting
as every call will land opening greeting if unity did not find the user or call handler with called extension.
07-15-2015 02:19 PM
its was setup like this before , i'm going to follow the instruction you gave me and I will let you know
08-05-2015 07:36 PM
Hello Ramasha
