How to simplify SRST Dial Plan and strip the 9 ?
lowfell
Level 3
Level 3
Hello all. instead of using a lod of dial peers in ym SRST MGCP fallback config I was thinking of using only these two
voice translation-rule 1
rule 1 /^.*\(.....$\)/ /\1/
voice translation-rule 2
rule 1 /^.*$/ /90\0/
voice translation-profile PSTN-Inbound-Translate
translate calling 2
translate called 1
dial-peer voice 1 pots
translation-profile incoming PSTN-Inbound-Translate
preference 1
incoming called-number .
direct-inward-dial
port 0/1/0:15
dial-peer voice 10 pots
description SRST calls to the PSTN
preference 1
destination-pattern 9.T
port 0/1/0:15
How do i strip the 9 from the outbound to the PSTN?
preference 1
port 0/1/0:15
Do I use
preference 1
forward-digits 11
port 0/1/0:15
Would the forward-digits 11 work ? i can see this working for a mobile number or a national, but what abouyt local say six digits?
would I have to add another dial-peer then? and then for other numbers extra dial peers, etc etc so I'd be back to another long list of dial peers then.
can i not just have a cover all  with the
preference 1
forward-digits 11 (or whatever ?)
port 0/1/0:15
Because that snip is for INBOUND matching, not OUTBOUND.
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
Now, assume that an incoming call arrives with no calling number information and is matched with the POTS dial peer based on the destination-pattern 9T command. In this case, the Cisco IOS router or gateway uses the "9" digit as the calling number and forwards the call to the corresponding device, such as CallManager or the IOS Gateway. In order to not replace the empty calling number field, create a dummy POTS dial peer with just the incoming called-number command configured. Because the incoming called-number statement has higher priority than destination pattern for inbound POTS matching, dial-peer voice 2 becomes the POTS dial peer used
java
if this helps, please rate
Thanks for that. is this saying then according to the example
In this example we have defined 9011T as the string for the destination-pattern.
With this in place we receive a call for 90113227045555. This matches our dial-peer for outbound call routing and the explicitly defined digits of 9011 are stripped off before the call is routed out the voice-port.
 destination-pattern 9011T
 port 0/0/0:23
 So using  MY example which is
preference 1
Is this supposed to STRIP the 9 then?
I'm confused because I found this article. does this  suggest the same pattern DOES NOT strip the 9
Special Note on POTS  Calls with Empty Calling Number Field
Assume this configuration:
   port 1/0:1
Now, assume that an incoming call arrives with no calling number information and is matched with the POTS dial peer based on the destination-pattern 9T command. In this case, the Cisco IOS router or gateway uses the "9" digit as the calling number and forwards the call to the corresponding device, such as CallManager or the IOS Gateway. In order to not replace the empty calling number field, create a dummy POTS dial peer with just the incoming called-number command configured. Because the incoming called-number statement has higher priority than destination pattern for inbound POTS matching, dial-peer voice 2 becomes the POTS dial peer used."
So  how do I strip the 9 then?
I've noticed my dial-peer has
which is different from
It's the DOT, so by using
destination-pattern 9.T                    I should be stripping the 9 for any outbound call, yes?
java
Hello and thanks again. so getting back to my question
If I am inside the hgateway and i want to ring a PSTN number i woulds usuaully dial 9 then the number.
Will this strip off the 9 before it sends it to the PSTN please yes or no?
preference 1
